unplugme71
- Jan 4, 2013
I'm looking to build a FreeNAS Home Server like most of us here. However, speed is definitely important for data transfers as I plan to have 2-3 devices streaming content at any given time with other computers accessing documents, photos, etc. I have two Apple TV's, iPhone, iPad, 2 Mac's, and 2 PC's. I would like to use AFP and SMB. I believe AFP is a better protocol for Mac's in terms of speed, but I could be wrong.
Here's the build I plan to do:
Intel Core i3-3220 (3.3GHz)
ASUS P8Z77-M PRO
2 x 4GB DDR3 Memory
1 x 128GB SSD (OS) - already have this SSD
8 x 3TB WD Red (Data)
430W EarthWatts PSU (is this enough for 8 drives?)
1) Should I create two Vdevs of 4 x 3TB in a Z2 config? Or just leave it as 1 Vdev?
2) Would 8GB Memory be sufficient? Would upgrading to 16GB actually gain any performance?
3) The motherboard doesn't support 9 SATA drives. Which add-on cards do you recommend?
4) Does this Intel NIC work with FreeNAS (Intel EXPI9402PT PRO/1000 PT Dual Port Server Adapter) ? Can it be teamed in FreeNAS? Can I use the onboard strictly for management login?
Thanks for your help!
ASUS P8Z77-M PRO
2 x 4GB DDR3 Memory
