Hello
After a lot of reading, I thought I'd post my plan for my freenas box before buying anything.
Motherboard: Asus P10S-I Mini Itx
CPU: Intel Core i3 7300
2x16 GB Samsung 2133 MHz ECC DDR4 (From manufacturer QVL)
HBA: IBM/Lenovo M1215, to be flashed to IT mode
PSU: Seasonic Prime 850 Watt 80+ Gold
System drive: Intel 540S SSD
HDD's: 10x Seagate Ironwolf 4 TB
Case: Lian Li PC-Q26 (bought a year ago)
CPU cooler: Noctua NH-D9L (If the stock cooler is too noisy)
Fans: Noctua Static pressure optimized. (If the stock fans isn't up to the task)
I also need an UPS, any recommendations here?
The HDD's will be in a 10 disk raid-z2 vdev
The nas will only have one client (me). And it won't be running any jails, except some r-sync in the future.
It will be running encryption. The I3 7300 supports AES-NI, but will the I3 be enough? Or should i consider a Xeon?
The HBA might be overkill, but I can't find any M1015 locally (Denmark). And I don't trust the cheap ebay ones from China.
The 32 GB ram is low balling it with 40 TB, according to the official hardware guide.
But since it will only serve me, and only do storage, it should be fine?
The content it will be storing is: 70% blu ray mkv rips, 20% smaller video files and 10% pictures, documents & music.
I know encryption isn't recommended, mostly due to people being bad at managing keys, passwords etc?
But I have been running everything I own encrypted for +8 years, and have never lost data, since i backup my keys to multiple locations, like a box in my bank.
I have been going back and fourth between the Seagate's Ironwolfs, WD reds, HGST's and enterprise grade drives. But I have decided on the Ironwolfs.
I run both WD Blues and Seagate Desktops in my desktop pc. Neither WD or Seagate have failed me, but my Seagates run 5°C cooler. Which will benefit me in the noise department, since it will be placed in my room. (I live in an apartment with others)
The Freenas will be replacing my current setup which is: 2x4 tb backed up to an 8 tb external, 1x2 tb backed up to my laptop with rslsync, and a 1x2 tb black game drive. No drives is in raid, jbod. Just a lot of different drives in windows. It's a pretty annoying to manage..
Have I missed something? Or is there something I could improve on? Pleas let me know, and thanks in advance :)
