Lindsay Horner
- Jun 3, 2016
Hi, I would be very grateful if people could run an eye over this setup, and give me some thoughts...
Case: In-Win IW-MS04-01 4-Bay ITX NAS with 265W Flex PSU
MB: Asus P11C-I + IPMI module
CPU: Core i3-9300F + Noctua NH-L9i cooler
RAM: 1X Samsung 16GB 2666 MHz ECC DDR4 (M391A2K43BB1-CTD)
Storage HDD: 4X 8TB Toshiba N300 in a RAIDZ2 zpool
Storage SSD: 2X Samsung 860 EVO 1 TB SATA 2.5 in mirrored zpool
Boot Storage: 2X SanDisk SDCZ430-032G-G46 Ultra Fit 32 GB (mirrored)
Network: Intel X520-SR1 Single Port SFP+
Main use:
HDDs: Backups of my workstation, and storage of archived projects.
SSDs: Storage of often-used assets (video, image sequences, installers etc).
I work as a 3D animator, so deal with a lot of large image sequences that can be 10-50GB each (10-100MB per frame) as well as large simulation caches that can be 50-200GB each (100MB-1GB per frame). I make backups of my workstation once a day (around 1-1.5TB total, probably 50GB of changes per day max) and store archived projects on the NAS (around 50-100GB each). I don't intend to work off the HDD storage, but I would work off the SSDs occasionally to access assets.
Secondary uses:
Plex server, music only. Unfi controller. Occasional Ubuntu VM.
The project archive is replicated off-site as well. I've done a fair bit of reading on mirrored vdevs vs RAIDZ2 and decided Z2 sounds easier and will have nearly the same throughput, although I maybe have got that wrong!
I realise I won't saturate the 10GbE link but I already have the network in place. The workstation is using NVMe SSDs and has 10GbE.
Space on my desk is limited hence the smaller case and ITX motherboard. I'm currently using a Qnap 2-bay NAS and would like to keep a similar-ish footprint and noise-level (I realise this one will probably be a bit louder). I suspect my current CPU/MB specs may be overkill, but I also want to keep this for a good few years. Suggestions on reducing power usage/noise are more than welcome! 5400RPM HDDs maybe? Celeron? Would I be better off with a 4 core Atom processor? (A2SDi-4C-HLN4F or similar)
Thanks in advance, Lindsay.
Main use:
Secondary uses:
