Just posting this to make sure I haven't done anything boneheaded in my component selection.
CPU: Intel Xeon E3-1230V3 Haswell 3.3GHz LGA 1150 80W Quad-Core Server Processor BX80646E31230V3 (The 1240v3 isnt much more expensive and has hyperthreading. Is that worth upgrading to?)
MOBO: SUPERMICRO MBD-X10SL7-F-O uATX Server Motherboard LGA 1150 Intel C222 DDR3 1600
RAM: SAMSUNG 8GB 240-Pin DDR3 SDRAM DDR3 1600 ECC Registered Server Memory Model M393B1K70DH0-CK008/Q8/E8 X 4 (This is the only component im really concerned about. I used the memory selector on the supermicro site, but none of the modules were available on newegg, this seemed the closest, does anyone have a better newegg or amazon suggestion?)
Case: Rosewill 1.0 mm Thickness 4U Rackmount, Black Metal/Steel RSV-L4411
Drives: 2x Seagate 3tb, 2x WD Red 3tb, 2x HGST Deskstar NAS 3tb in RaidZ2 (I would have gone with 4tb but i alread have 3 of these drives. They are all 64mb chache and the segate and the hgst are 7200 rpm) I have plans to add a second 6 drive raidz2 pool later
Power Supply: SeaSonic SS-520FL2 520W
Im excited to get this all in and start building!
