I plan to build my first DIY NAS, and I look then for some advises.
My goals are:
Based on the informations I have captured on this forum (thanks for it by the way), I'm convinced that ECC memory is the way to go to avoid enormous potential disaster!
But ECC means, supported MB, CPU and RAM ... and this is mostly an unknown world to me ...
Can you please help me figure out what kind of HW is the best fit for my above needs:
Can you also clarify if my idea to add a separate HDD to store non critical backups/data (like disk image of my other PCs...) is ok?
Thanks in advance for your comments :)
My goals are:
- Home usage to store files and stream pictures, movies and music in the house (XBMC, Sonos, JRiver applications running on other computers will access the shared datas on the NAS).
- +/-10TB usable storage capacity
- 1 additional HDD (2TB) to store non critical backups
- Reasonable budget with good purchase conditions in Europe (I'm from Belgium)
- MB: SuperMicro seems very expensive, maybe some AsRock or Asus can be good cheaper alternative?
- CPU: Xeon is probably an over kill for my needs, go for i3 or even lower??
- RAM: I would probably go with 16GB (2x8) ECC
- HDDs: RaidZ1 or RaidZ2, with how much disks of what capacity?
