PhiloEpisteme
- Oct 18, 2018
Hey folks, looking for some build advice. I've tried to be as detailed as possible re the parts I am interested in and my reasoning. Hopefully it isn't too verbose.
I've been reading the forums and advice online and think I've gotten close to narrowing down my build. I'd like to use my NAS to store important personal and business data as well as photos, videos, and backups of other machines I've got around. To start I will likely not access the server outside of my LAN but eventually will likely want to explore using it as a personal cloud and possibly as a media server to show friends and family photos and videos while away from home.
Motherboard - Supermicro - X11SSM-F
I've considered a lot of boards and based on advice found in the Forums and Resources pages. I am primarily focused on the following Supermicro boards.
C232
X11SSL-F 6 x SATA, Dual 1 Gb/s Lan
X11SSL-CF 6 x SATA, 8 x SAS, Dual 1Gb/s LAN
C236
X11SSH-F 8 x SATA, 1 M.2, Dual 1Gb/s LAN
X11SSM-F 8 x SATA, Dual 1Gb/s LAN
X11SSH-TF 8 x SATA, M.2, Dual 10Gb/s LAN (The newegg link suggests it is 1Gb/s but the supermicro site shows the board using the Intel x550)
X11-SSH-CTF 8 x SATA, 8 x SAS, Dual 10Gb/s LAN (Same as above where the supermicro site suggests the LAN is 10Gb/s but newegg does not)
After reading the 10 Gig Networking Primer page I am leaning away from the X11SSH-TF and X11-SSH-CTF as both have Intel NICs. If I decide to go with 10Gb in the future I will buy a card to do so.
This leaves me with thoughts of future expansion, which requires PCIe slots. For that reason I am shying away from the two C232 boards.
I don't see a need for the M.2 slot on the X11SSH-F and so that leaves me with the X11SSM-F. It has 4 PCI slots (2 x 8x and 2 x 4x) which gives me plenty of room to add HBAs and NICs.
Q: Is there a compelling reason to get a board with M.2 slots instead of with more PCIe slots?
Q: Am I making a mistake going with the LGA-1151 boards? Is it overkill or will I need something capable of more if I decide to use the box for streaming?
CPU - Intel Core i3-7100 3.90 GHz 51W TDP
Based on the recommendations found in the FreeNAS® Quick Hardware Guide there are no LGA-1151 recommendations for the medium range. I worry that as I use the server for more I may regret buying a CPU with less power so I tried to find a similar CPU in the LGA-1151 socket to match my board. With that I came to the Intel Core i3-7100. I'm happy to consider other CPUs but I plan to make use of encryption so a CPU which supports AES-NI would be important.
Q: Is the Intel Core i3-7100 too much CPU for my NAS if I plan to use it as a media server and personal cloud?
Memory - 32GB (2 x 16) Crucial DDR4 SDRAM ECC 2133
Supermicro did not have a large list of tested memory, nor did they have much that was not super low profile memory. I think perhaps there may be some information I am missing. My goal is to purchase 32GB ECC memory on 2x16GB DIMMs so I can expand to 64GB later if I need to. Something like the Crucial 32GB (2 x 16GB) 288-Pin DDR4 SDRAM ECC DDR4 2133.
Chassis - Fractal Design Define R6
For my first build I'd like something like the Fractal Design Define R6. I like that it supports 11 HDDs (if you buy extra HDD brackets) and 2 SSDs to boot.
Boot Drive - 120GB WD Green SSD SATA III 6Gb/s - WDS120G2G0A
I've got one lying around. So long as it won't hurt anything I might as well use it.
Storage
Pool1 - RAIDZ2 vdev
3 x 7200RPM 2TB Toshiba P300 HDD SATA 6Gb/s 64MB Cache - HDWD120XZSTA (Already Own)
1 x 5400RPM 2TB WD Red NAS HDD SATA 6Gb/s 64MB Cache - WD20EFRX
Pool2 - RAIDZ2 vdev
3 x 7200RPM 3TB Seagate Constellation ES.3 HDD SATA 6Gb/s 64MB Cache - ST3000NM0033 (Already Own)
3 x 5400RPM 3TB WD Red NAS HDD SATA 6Gb/s 64MB Cache - WD30EFRX
I already own the 3 Toshiba and Seagate drives so I would like to use them if I can get some mileage out of them.
Q: What am I really risking by not using NAS drives? Is it simply that they will fail faster? Or will they corrupt my data or cause the vdev to become corrupted and therefore ruin my pool? I am totally happy if they die faster since I have no other use for them and happy to give them a job.
Q: Is it acceptable to mix the 7200RPM drives with the 5400RPM drives? I found several posts, including this one, which suggests it is okay.
HBA - LSI SAS 9207-8I
As the X11SSM-F 'only' supports 8 SATA drives I would consider picking up an HBA. To start I would likely be attaching SATA drives to it but may upgrade to SAS. Even with SAS if I only use up to 8 HDDs on the HBA would I need anything with more throughput than the LSI SAS 9207-8I? I had a somewhat hard time finding good sources of new cards. There are a TON of used cards out there but I worry about the reliability of a used card. Am I perhaps not looking in the right places or are there newer parts to consider?
PSU - Seasonic Prime Titanium 650W - SSR-650TR
I realize this is on the pricier side for a PSU but I like that it is a trusted brand and more energy efficient. I'm not too concerned about making my money back on the extra cost. I'm mostly interested in whether the 650W will be enough to power my machine.
C232
C236
Storage
Pool1 - RAIDZ2 vdev
Pool2 - RAIDZ2 vdev
