thesecfreenas
- May 14, 2019
Hello Community,
You are looking at my first build! I went through the parts list and I was looking for some expert advice.
I did some research, but I am sure that I will miss something :)
What I am trying to achieve is a very reliable NAS to trust my DSLR photos, and share files between the computers, TVs and cell phones at home. I am not expecting to have a lot of jails. transmission I will have for sure and maybe plex. My main objective is to build something that I don't need to be worried about loosing data. I am not too bothered about performance. In terms of budget, I would like to stay below £800, but from what I am looking at the moment, I am close to £1000 :( Everything is more expensive in the UK
Case - Fractal Design Node 804
£105.00 "https://www.amazon.co.uk/Fractal-De...gn+Node+804&qid=1557527242&s=computers&sr=1-1
Tried to find something smaller and cheaper, but nothing with enough space for HDs.
Power supply - Seasonic FOCUS Plus Gold 550W SR-550FX £75.00
https://www.amazon.co.uk/Seasonic-F...psu+450&qid=1557572565&s=gateway&sr=8-1-fkmr1
Should be enough to power everything and have something left.
CPU - Intel Core i3-6320 3.9 GHz LGA 1151 Processor £144.99
https://www.amazon.co.uk/Intel-BX80662I36320-Core-i3-6320-Processor/dp/B015VPX48I/ref=sr_1_4?crid=3JYW5NQD7KQ1R&keywords=intel+6300&qid=1557576249&s=computers&sprefix=intel+63,computers,129&sr=1-4
Motherboard - Supermicro X11SSM-F £216.00
https://serverfactory.co.uk/components/motherboards/supermicro-x11ssm-f-motherboard.html
IPMI, 8 SATA (6 HD RAIDZ2 + 2 SSDs for Boot)
RAM - Crucial CT2K8G4DFS8266 16 GB Kit (8 GB x 2) DDR4 2666 MT/s £87.39
https://www.amazon.co.uk/Crucial-CT...am+16gb+udimm&qid=1557599380&s=gateway&sr=8-6
SSD OS - Kingfast 2.5 Inch Internal 32GB SATA 3.0 2x£8.76 £17.52
https://www.amazon.co.uk/KingFast-I...SATA&qid=1557867460&s=gateway&sr=8-1-fkmrnull
FANS - Noctua NF-A14 PWM 2 £18.90 £37.80
https://www.amazon.co.uk/NF-A14-PWM.../dp/B00CP6QLY6/ref=sr_1_2?keywords=noctua+nf-
a14+pwm+140mm&qid=1557869898&s=gateway&sr=8-2
Two additional FANS for the HDs
Disk - Seagate 1 TB IronWolf 3.5 Inch 5900 RPM Internal Hard Drive for 6x £50.99 £305.94
https://www.amazon.co.uk/dp/B01LXUFPY9/ref=psdc_430527031_t2_B008JJLXO6
It will give me 4TB, more than enough for me right now.
Extras +2 SATA cables, because the motherboard only comes with 6 SATA cables
Like I mentioned, for data RAIDZ2 and SSD mirroring for the OS. I didn't bought anything yet and I didn't found anything 2nd hand.
I appreciate your feedback. Apologies for my bad English.
EDIT: The box is going to be in my living room, so being quiet is a requirement.
UPDATE 01/06/2019:
I have end up buying the following so far, taking your advice:
CASE Fractal Design FD-CA-DEF-MINI-BL Define Mini - £81
https://www.amazon.co.uk/Fractal-De...DEF-MINI-BL&qid=1558045977&s=computers&sr=1-2
Why? Smaller, more quiet and with enough capacity for my needs. Following KrisBee advice
Motherboard Supermicro X11SSM-F £124 Refurbished on ebay, great deal!
Why? This was the most expensive part of the build. This was an amazing opportunity, and the board was in excellent condition
Following KrisBee advice as well. Some good deals exists, you just have to be patient.
RAM Kingston KSM24ED8/16ME 16GB ECC Memory DDR4 SDRAM 2400 £139
https://www.amazon.co.uk/Kingston-K...KSM24ED8/16ME&qid=1559416254&s=gateway&sr=8-1
Made the correction since I have missed it. Thank JohnnyGrey and remaining!
It's much cheaper now
I might buy another one just to add some VMs.
CPU Intel Core i3-6320 3.9 GHz LGA 1151 Processor £144.99
Bought what I have initially planned.
OS DISK Intel SSDSC2KW128G8X1 545s Series 128 GB 2.5-Inch £26.99
Why? more reliable and not very expensive. taking Chris Moore advice
Bought what I have initially planned. Seems an amazing Power supply, completely modular.
TO BE BOUGHT:
4x 2TB WD RED Drives £65 = £260
I am going to use a ZRAID 2. Easier to upgrade and reliable enough. Again, thanks KrisBee for the advice
At least one Noctua NF-S12A for the front of the case to keep the disks cool and extend their life span. £17.65
No need for the extra SATA cables anymore.
I am still under £1000 due to the refurbished motherboard
I will update you once I complete the build. Thank you all for your precious comments. Please let me know your comments below
UPDATE 01/06/2019:
TO BE BOUGHT:
