First Server build, would this work?
Znow
This is my first sever build, so i have no idea what im doing any help would be appreciated.
The server is going to be a backup sever to my computers, i thinking of running some sort of redundancy on it not sure what type yet. I trying to keep the buget low, and im thinking of having 3-6 drives 2 tb each
so here's the parts list, i know most of the part are semi old but im not sure what i should upgrade them to.
Case: Bitfenix Nova Midi https://www.amazon.co.uk/Bitfenix-N...&qid=1468453966&sr=8-3&keywords=BitFenix+case
Motherboard :ASRock E3C224D2I https://www.amazon.co.uk/ASRock-E3C...949&sr=8-1&keywords=asrock+server+motherboard
Cpu : Intel Pentium G3450 https://www.amazon.de/Intel-BX80646...&qid=1501595862&sr=1-1&keywords=Pentium+G3450
Ram: Kingston KVR16E11 https://www.amazon.co.uk/gp/product...0-2ad7-412c-8634-6cd03b7b73e2&pf_rd_i=desktop , 16 gb of it
Psu: Seasonic SS-430GB Active https://www.amazon.de/Seasonic-SS-4...=UTF8&qid=1468505072&sr=8-3&keywords=seasonic
Hdd : WD 2 TB NAS https://www.amazon.co.uk/dp/B008JJLZ7G/ref=twister_B01F8OL790?_encoding=UTF8&psc=1
So if anyone could help me update or change it so it would be better or just guid me towards a better build that would be great ;)
SweetAndLow
Sweet'NASty
What do you want to use the system for? It looks like you read the hardware guide which is great. We can help steer you more if you tell use what your use case and goal for the system is.
Znow
Its going to be for backing up files from my many different computers, and also storing photos and videos, for my different projects.
iammykyl
True but i would love to build one my self, part of the fun!
I build PCs as an extra income and is very satisfying to see the finished working build, but, extra care needed that everything is compatible.
Future expand-ability is very important. Even when the budget is tight, don't compromise. judicious shopping can help.
Your "thinking of having 3-6 drives", the Bitfenix Nova Midi, only has 4 3.5" bays and one rear fan included, so you will need front fans for proper airflow.
If you want to stay with a small form factor build http://www.ebuyer.com/393752-fractal-design-node-304-mini-itx-case-fd-ca-node-304-bl
or, Mid Tower, starting about here, https://www.aria.co.uk/Products/Com...ource=uk.pcpartpicker.com&utm_medium=referral
Znow
Yeah i was planning to get a bigger case later down the road when i have some more cash, i was going to start with 3 drives and then expand in the future to 5, but ill take a look at thoes cases they seem to be more suitable, thansk
