First off thanks for all the help.
I'm trying to move data from my old Synology Diskstation to my new FreeNAS box. I have 25+ tb of data that need to be moved. I first tried over the network and that is just way to slow.
My latest action is to use a spare HDD and sneakernet it across. I was using an old 2Tb drive and it was working ok. So I bought a 12Tb drive and tried it. I formatted the drive with GPT and EXT2 from the Synology. Copied a large chunk of my Meda to the 12 Tb drive. Installed it in the FreeNAS and used the import drive utility to import into the correct pool. This seemed to work flawlessly but then I noticed of the 12 TB only about 1.8 is seen. All the root folders were copied to the disk seem to be there but the subfolders and/or files are missing.
I tried to manually mount the drive in FreeNAS but receive an error from what I can figure out this can be mounted as read-only. With that done and I search the FS I'm still missing the files and folders. I see no rime or reason it's happening if I compare permission between files that are present on the host system I see no difference. The files are not outrageously large. I even looked to see if the missing files have characters that could make them unreadable in the path. None of that seems to be the cause.
2Tb vs 12Tb Parted Print Output
Again any help would be greatly appreciated. This is driving me nuts.
freenas# mount -t ext2fs /dev/da5p1 /mnt/drive/
mount: /dev/da5p1: Operation not permitted
But this works
mount -o ro -t ext2fs /dev/da5p1 /mnt/drive/
print Model: WDC WD2002FYPS-02W3B (scsi) Disk /dev/sdgd: 2000GB Sector size (logical/physical): 512B/512B Partition Table: msdos Disk Flags: Number Start End Size Type File system Flags 1 1049kB 2000GB 2000GB primary (parted) print print Model: ATA ST12000VN0007-2G (scsi) Disk /dev/sdge: 12.0TB Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags: Number Start End Size File system Name Flags 1 1049kB 12.0TB 12.0TB ext2
