Hello, All
When you copy the ISO file that you have saved on the PC onto the FreeNAS, you have encountered a phenomenon file transfer stalls must always 95%.
But if the file size of about 1GB copy without problems complete, or if the file size is more than 3GB and progress goes up to 95%, it would stop because of a network error.
For this problem, do you have already been reported?
If I, if for the first time problem, what should I provide any such information to you guys?
Check to have build:
FreeNAS-9.3-STABLE-201501241715
[root@freenas] ~# cat /usr/local/etc/smb4.conf
[global]
server max protocol = SMB2
interfaces = 127.0.0.1 192.168.122.200
bind interfaces only = yes
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 706754
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = no
directory name cache size = 0
kernel change notify = no
ea support = yes
store dos attributes = yes
unix extensions = no
null passwords = yes
acl allow execute always = true
acl check permissions = true
dos filemode = yes
domain logons = no
idmap config *: backend = tdb
server role = standalone
netbios name = FREENAS
workgroup = WORKGROUP
security = user
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP932
unix charset = UTF-8
log level = 1
[filesrv_cifs]
path = /mnt/zvol/zset_cifs
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
recycle:repository = .recycle/%U
recycle:keeptree = yes
recycle:versions = yes
recycle:touch = yes
recycle:directory_mode = 0777
recycle:subdir_mode = 0700
vfs objects = zfsacl aio_pthread streams_xattr
hide dot files = no
guest ok = yes
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
[root@freenas] /var/log/samba4#tail log.nmbd
STATUS=daemon 'nmbd' finished starting up and ready to serve connectionsGot SIGTERM: going down...
[2015/01/25 06:10:47, 0] ../source3/nmbd/nmbd.c:907(main)
nmbd version 4.1.13 started.
Copyright Andrew Tridgell and the Samba Team 1992-2013
[2015/01/25 06:10:47.942538, 0] ../lib/util/become_daemon.c:136(daemon_ready)
[2015/01/25 06:17:41, 0] ../source3/nmbd/nmbd.c:907(main)
[2015/01/25 06:17:41.486170, 0] ../lib/util/become_daemon.c:136(daemon_ready)
[root@freenas] /var/log/samba4#tail log.smbd
[2015/01/25 06:10:48.339943, 0] ../lib/util/become_daemon.c:136(daemon_ready)
[2015/01/25 06:17:41, 0] ../source3/smbd/server.c:1189(main)
smbd version 4.1.13 started.
[2015/01/25 06:17:41.608120, 1] ../source3/smbd/files.c:218(file_init_global)
file_init_global: Information only: requested 706754 open files, 59392 are available.
[2015/01/25 06:17:41.914785, 0] ../lib/util/become_daemon.c:136(daemon_ready)
STATUS=daemon 'smbd' finished starting up and ready to serve connectionsariel (ipv4:192.168.122.30:56327) closed connection to service filesrv_cifs
STATUS=daemon 'smbd' finished starting up and ready to serve connectionsariel (ipv4:192.168.122.30:56354) closed connection to service filesrv_cifs
STATUS=daemon 'smbd' finished starting up and ready to serve connectionsariel (ipv4:192.168.122.30:57040) closed connection to service filesrv_cifs
log.nmbd log.wb-BUILTIN log.winbindd log.winbindd-locator
log.smbd log.wb-FREENAS log.winbindd-idmap
[root@freenas] /var/log/samba4# tail log.winbindd
[2015/01/25 06:10:48.100800, 0] ../source3/winbindd/winbindd_cache.c:3196(initialize_winbindd_cache)
initialize_winbindd_cache: clearing cache and re-creating with version number 2
[2015/01/25 06:10:48.121952, 0] ../lib/util/become_daemon.c:136(daemon_ready)
STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=1)
[2015/01/25 06:17:41, 0] ../source3/winbindd/winbindd.c:1489(main)
winbindd version 4.1.13 started.
[2015/01/25 06:17:41.657134, 0] ../source3/winbindd/winbindd_cache.c:3196(initialize_winbindd_cache)
[2015/01/25 06:17:41.671723, 0] ../lib/util/become_daemon.c:136(daemon_ready)
[root@freenas] /var/log/samba4# tail /var/log/messages
Jan 25 06:36:00 freenas smbd[5243]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsariel (ipv4:192.168.122.30:56354) closed connection to service filesrv_cifs
Jan 25 06:47:12 freenas smbd[10716]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsariel (ipv4:192.168.122.30:57040) closed connection to service filesrv_cifs
[global]
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
load printers = no
printing = bsd
getwd cache = yes
ea support = yes
dos filemode = yes
domain logons = no
security = user
create mask = 0666
dos charset = CP932
log level = 1
[filesrv_cifs]
printable = no
writeable = yes
browseable = yes
recycle:touch = yes
hide dot files = no
guest ok = yes
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
