Fatal Trap 9 after upgrading to 8.3.1-RELEASE-x64
greenhobby
Hi All,
Received this first thing this morning:confused:. I upgraded from 8.3.0 to 8.3.1 yesterday. System had a scheduled scrub on one of the volumes. Any ideas?
Thanks in advance for helping!!
-gh
Dell XPS running 1.6GHz (underclocked), 4GB mem,
four 1 TB Hitachi's in ZFS RAID 5
one 3 TB WD in ZFS (Vol-Backup)
Boot from USB Dongle (8.3.1)
greenhobby
Thanks very much guys! I've downloaded P2 and I've upgraded to it. I'll see what it does in the morning since the large Volume gets scrubbed tonight.
Regards,
-gh
greenhobby
So I updated to 8.3.1-P2 and it crashed the same way as the night before :mad:. I started looking around at some of the customization's that I've done to a standard install. I had setup the disks to power down after 20 minutes and go into low power. It seems as though the system crashes while attempting a scrub when the disks are spun down :confused:. I set the disks to be always on and the problem went away. The system seems rock solid now (even with scrubs). Not sure if this is a bug or feature or something to stay away from.
Anyway thanks for the replies to help.
-gh
It sounds to me like your zpool might have some corruption that is irreparable. Can you post the output of smart info for each of your drives and zpool status? Put each one in code tags so its legible.
greenhobby
Kinda of a noob on the smart info gathering. How do I do that? Here is the zpool status with a scrub currently going on on Vol-Backup (which contains both Win8 and TimeMachine backups)
[carey@clanker] /# zpool status -v
  pool: Vol-Backup
 state: ONLINE
  scan: scrub in progress since Sun Apr 14 14:41:40 2013
        1.32T scanned out of 1.60T at 114M/s, 0h42m to go
        0 repaired, 82.60% done
        NAME                                          STATE     READ WRITE CKSUM
        Vol-Backup                                    ONLINE       0     0     0
          gptid/57b92013-9acd-11e2-8d1c-001aa0c1863e  ONLINE       0     0     0
errors: No known data errors
  pool: Vol-Raid5
 state: ONLINE
  scan: scrub repaired 0 in 1h14m with 0 errors on Thu Apr 11 08:23:51 2013
        Vol-Raid5                                       ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/d844ebd1-9bcb-11e2-b577-001aa0c1863e  ONLINE       0     0     0
            gptid/d8a7c730-9bcb-11e2-b577-001aa0c1863e  ONLINE       0     0     0
            gptid/d9088f64-9bcb-11e2-b577-001aa0c1863e  ONLINE       0     0     0
            gptid/d9689788-9bcb-11e2-b577-001aa0c1863e  ONLINE       0     0     0
[carey@clanker] /#
thanks in advance again for helping out!
-gh
