Henning Kessler
- Feb 10, 2015
I have an issue with a VMWare snaphot producing constant errors for a single VM which is hosted on a iSCSI zvol on my FreeNAS.
"The following VM failed to snapshot mypool/iscsi@auto-20160414.1800-2w:
[iscsi] ELK/ELK.vmx"
I can do snapshots from the VM on the ESXI system without any errors. When try to do a manual snapshot from my FreeNAS system I can see on the ESXI host that the snaphot is made successfully on another VM but fails on the other with the following output:
Traceback:
What can I do?
Specs
FreeNAS
FreeNAS-9.10-STABLE-201604111739
16GB RAM
HP Proliant Gen8 Microserver
4x 4TB WD Red in stripped mirrors
ESXI
ESXI 6.0.6 u2 (Build 3620759)
Macmini6,2
16GB RAM
VM
FreeBSD (64Bit) 10.3
VM-Version 8
1GB RAM
VMWare Tools 10246
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 156. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in manualsnap 715. form.commit(fs) File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in commit 1865. vm1.create_snapshot(vmsnapname, description=vmsnapdescription, memory=False) File "/usr/local/lib/python2.7/site-packages/pysphere/vi_virtual_machine.py" in create_snapshot 889. FaultTypes.TASK_ERROR) Exception Type: VIException at /storage/snapshot/create/mypool/iscsi/ Exception Value: [Task Error]: An error occurred while saving the snapshot: Failed to quiesce the virtual machine.
What can I do?
Specs
FreeNAS
16GB RAM
ESXI
Macmini6,2
16GB RAM
VM
VM-Version 8
1GB RAM
VMWare Tools 10246
