adamthekiwi
- Jan 17, 2012
Hi folks,
I've had a nas4free server at home, pretty much untouched since installation (and that was just after the fork) - so, well behind the curve in terms of versions. It's worked OK without intervention, albeit a bit slow, but I finally decided to build a new machine. My intention at this stage is to keep the old one as a backup server (probably mostly off, with the occasional WoL to bring it back to life and perform a sync before going back to sleep) but I'm open to other suggestions.
I have a shiny new Supermicro-based system with a fresh install of FreeNAS 11.1. I was going to NFS mount the old storage onto the new machine to clone it - it will take time over a gigaeth network, but I'm not too fussed about that. I'm struggling, though - can anyone assist?
I've enabled NFS on the Nas4Free server and shared the main zfs pool.
Can anyone help or suggest an alternative method?
Cheers - Adam
gaeta% sudo mount adam@192.168.1.3:/mainstore01 ./tyrol mount: adam@192.168.1.3:/mainstore01: No such file or directory gaeta% sudo mount -t nfs adam@192.168.1.3:/mainstore01 ./tyrol mount_nfs: adam@192.168.1.3: Non-recoverable failure in name resolution gaeta% ssh adam@192.168.1.3 -oHostKeyAlgorithms=+ssh-dss ls -l /mainstore01 adam@192.168.1.3's password: total 24 drwxrwxr-x 3 adam twentyfive 4 Dec 14 19:07 EdiFerm drwxrwxr-x 9 adam wheel 9 Nov 16 2015 OSstorage drwxrwxr-x 6 adam thornville 6 Mar 4 2014 Share drwxrwxr-x 2 adam thornville 37 Mar 3 2014 dev drwxrwxr-x 12 adam thornville 25 Mar 1 10:43 media drwxrwxr-x 11 adam thornville 31 Apr 6 19:53 techview
Cheers - Adam
