Failed to import zpool
dgraybill
I recently replaced the drive my FreeNAS runs on, with the intention of just importing the ZPool. The pool shows up in the GUI under auto import, so I tried that to no avail. I read a lot online about importing it first in CLI so I tried that numerous times, even using zpool import -f Storage, and I keep getting an error, "one or more devices is currently unavailable. I have not had any problems with the pool in the past, and when I run zpool import, it shows the pool, and all the drives in the pool as "ONLINE". I've been on google for hours now and i'm not finding anyone with the same problem.
Thanks for the help
Stephens
I can't answer your question, but please provide your FreeNAS version for those who can.
There's a process documented in the documentation for replacing drives. Did you follow it? Without even reading it myself, seems to me you're supposed to offline the drive, replace it, and on-line it. You can read for yourself what the exact process is.
paleoN
Do you have the original and does it still work?
It helps to actually understand the commands you are running. ;)
I would use 8.3.0-RC1 to attempt recovery as it has the improved ZFS v28 code in it. Burn that to a new USB drive and try from there. No -f imports unless you know what you are doing.
paleoN
Too bad. I was hoping you could pull the original zpool.cache file off. You sure you didn't have another disk in there somewhere: a stripe, log or cache? For each disk/partition in the pool:
zdb -l /dev/adaXp2
Assuming they all match each other post one of them.
dgraybill
They do not all seem to match. Here is the output:
LABEL 3
version: 15
state: 0
txg: 6833
pool_guid: 17646329889008502608
hostid: 1956700126
hostname: ''
top_guid: 8476132071472504239
vdev_tree:
type: 'disk'
path: '/dev/ada0p2'
whole_disk: 0
metaslab_array: 26
metaslab_shift: 33
ashift: 9
asize: 998052462592
is_log: 0
[root@freenas ~]# zdb -l /dev/ada0p2
LABEL 3
version: 15
state: 0
txg: 6833
hostid: 1956700126
hostname: ''
top_guid: 5895470883330402436
vdev_tree:
type: 'disk'
path: '/dev/ada1p2'
whole_disk: 0
metaslab_array: 23
metaslab_shift: 34
ashift: 9
asize: 2998440558592
is_log: 0
[root@freenas ~]# zdb -l /dev/ada1p2
LABEL 3
version: 15
state: 0
txg: 6833
hostid: 1956700126
hostname: ''
top_guid: 2720693610616754064
vdev_tree:
type: 'disk'
path: '/dev/ada2p2'
whole_disk: 0
metaslab_array: 69
metaslab_shift: 31
ashift: 9
asize: 397936164864
is_log: 0
[root@freenas ~]# zdb -l /dev/ada2p2
dgraybill
LABEL 3
version: 15
state: 0
txg: 6833
hostid: 1956700126
hostname: ''
vdev_tree:
type: 'disk'
path: '/dev/ada0p2'
whole_disk: 0
metaslab_array: 26
metaslab_shift: 33
ashift: 9
asize: 998052462592
is_log: 0
dgraybill
LABEL 3
version: 15
state: 0
txg: 6833
hostid: 1956700126
hostname: ''
vdev_tree:
type: 'disk'
path: '/dev/ada1p2'
whole_disk: 0
metaslab_array: 23
metaslab_shift: 34
ashift: 9
is_log: 0
dgraybill
LABEL 3
version: 15
state: 0
txg: 6833
hostid: 1956700126
hostname: ''
vdev_tree:
type: 'disk'
path: '/dev/ada2p2'
whole_disk: 0
metaslab_array: 69
metaslab_shift: 31
ashift: 9
asize: 397936164864
is_log: 0
paleoN
That's a dumb pool setup of, at least, a 3 disk stripe. I was thinking it was a 3 x disk raidz1. You never answered my other question.
The labels appear fine to me aside from not being in [code][/code] tags, which makes them harder to read.
dgraybill
Shell
[root@freenas ~]# zpool import -f -r /mnt/Storage
cannot import '/mnt/Storage': no such pool available
[root@freenas ~]# zpool import -f -r Storage
cannot import 'Storage': one or more devices is currently unavailable
[root@freenas ~]#
William Grzybowski
No, that is not that I told you to type, it was easy as ctrl+c+v:
# zpool import -fF -R /mnt Storage
It is case-sensitive, there is a space between /mnt and Storage
dgraybill
Sorry, I was using RDP on my cell phone driving across Nebraska, I misread what you typed, and I couldn't copy paste because my android doesn't share its clipboard with my RDP program. It ran that command for approximately 2 hours, and when I came home my shell window was closed so I can't give you the exact output, but it was something to the effect of ignoring 37 seconds of transmission, and that 'storage' returned to its previous state. Now, if I go to auto import in the GUI, storage is no longer listed there, and when I run 'zpool import' from the CLI, storage is no longer listed there either.
dgraybill
So far so good, now as long as I don't lose any more OS drives. Guess I'll set it up to back up somewhere. What exactly does ignoring 37 seconds of transmission mean?
dgraybill
WARNING: The volume Storage (ZFS) status is UNKNOWN: One or more devices has experienced an error resulting in data corruption. Applications may be affected.Restore the file in question if possible. Otherwise restore the entire pool from backup.
This shows in the GUI, but all the drives show as online.
If everything is fine with your ZFS pool, a reboot will likely fix the issue. I have previously posted that there's some inconsistency on when the ZFS status actually changes. I'd recommend you do a reboot.
dgraybill
I tried that, and it still shows the same. I can read and write data so I don't know what it's so upset about.
