[EZFS_IO] Failed to import 'MasterPool' pool: I/O error
zsw12abc
Hey Mates,
I faced an issue on my TrueNAS-SCALE-22.02.4
I tried to import my MasterPool from web UI
and it shows the error message below
And i saw a video with
zpool import -fFX MasterPool
to fix it
but that command runs whole night and didnt finish.
Please help me.
错误: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 411, in import_pool
zfs.import_pool(found, pool_name, options, missing_log=missing_log, any_host=any_host)
File "libzfs.pyx", line 1168, in libzfs.ZFS.import_pool
File "libzfs.pyx", line 1196, in libzfs.ZFS.__import_pool
libzfs.ZFSException: I/O error
File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 114, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1276, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 417, in import_pool
self.logger.error(
File "libzfs.pyx", line 411, in libzfs.ZFS.__exit__
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 415, in import_pool
raise CallError(f'Failed to import {pool_name!r} pool: {e}', e.code)
middlewared.service_exception.CallError: [EZFS_IO] Failed to import 'MasterPool' pool: I/O error
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 446, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1401, in import_pool
await self.middleware.call('zfs.pool.import_pool', guid, opts, any_host, use_cachefile, new_name)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1345, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1302, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1308, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1223, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor
zsw12abc
please help me
Arwen
Please follow the forum rules with your hardware setup, pool configuration and any preceding events.
Supply the output of zpool import in code tags.
zsw12abc
Hey @Arwen , thanks for helping me.
Here is the screenshot
zsw12abc
    self.logger.error(
    await self.future
Arwen
Well, ZFS sees all the disks for the MasterPool, so the question comes up what is causing the I/O error.
zsw12abc
Sorry @Arwen, I am new here and don't know how to create the hide button as others did.
Motherboard: Z370
CPU: i7 8700K
GPU: none
M2 SSD: Samsung 960
Sata SSD: Samsung 660
HHD *4: WD Blue * 2 + WD Red * 2 (All of them are 2TB Each)
The issue happened after the power outrage.
It was working before and there is 2 pools in my TrueNas.
The MasterPool (in 4 HDD) is disconnected after Power Outrage but the other pool (in SSD) is still working.
So I exported the MasterPool and tried to import it again then face this I/O issue.
Arwen
Their is a known problem with some Western Digital Red disk drives. Please supply the model and firmware version for them. You can get this information from using smartctl -a /dev/XXX against the device.
zsw12abc
Hey @Arwen is this the one u want?
zsw12abc
Here is the screenshots for all 4 HDD
Arwen
Looks like your 2 WD Reds are CMR, (aka Red Pluses). One of your WD Blues is SMR, but I don't know if that affects your pool and it's problem.
I have no further suggestions.
zsw12abc
Thank @Arwen . I also dont think CRM and SMR will effect importing pool.
Now i am trying
zpool import -fFX Masterpool
but do u know how long will this command runs?
last time, it ran for 5 days and still not finished.
