Export Freenas settings
robertjan11
Dear all
Is there a way to export my settings unless the settings of the jail and plugins? I want to do a clean install of freenas 9.1 and put back the settings like the user authorizations settings and volume settings but I don't want to put the old plugins back in it.. Because the 8.2 plugins are not compatible with 9.1 AND my old plugin/jail settings are à mess.. I only use 2 kind of plugins so I can setup this one manual but I have a lot of user settings and volume settings.. I known there is a way to just upgrade the jail but I don't what this bequase the old are really are mess and is asking for troubles..
also a reason for this is that I have a lot of very imported data on my NAS like backup security records from 3 local shops.. So the volume settings and user settings are very importend!
Thanks a lot!
pirateghost
Unintelligible Geek
Turn off and delete plugins on old system
Make config backup
Upgrade to new system
Import config
Configure plugins.
