AirborneTrooper
- Jun 20, 2014
Starting from scratch for Ombi. I have everything extracted to /usr/local/share/Ombi. Do I need to make a rc.d like I did for Radarr?
I am going to take a more indepth look at Ombi when I get a bit more free time which hopefully will be later this week.
I might also just stick with OmbiV3 until V4 stabilizes
./Ombi
Can you share yours? I don’t know what files to all point to by looking at the Radarr example.you can use a simple rc file to start it automatically
root@ombi:/usr/local/share/Ombi # ./Ombi
#!/bin/sh # $FreeBSD$ # # PROVIDE: ombi # REQUIRE: LOGIN # KEYWORD: shutdown # # Add the following lines to /etc/rc.conf.local or /etc/rc.conf # to enable this service: # # ombi_enable: Set to YES to enable ombi # Default: NO # ombi_user: The user account used to run the ombi daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run as root. # Default: ombi # ombi_group: The group account used to run the ombi daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run with group wheel. # Default: ombi # ombi_data_dir: Directory where ombi configuration # data is stored. # Default: /var/db/ombi . /etc/rc.subr name=ombi rcvar=${name}_enable load_rc_config $name : ${ombi_enable:="NO"} : ${ombi_user:="ombi"} : ${ombi_group:="ombi"} : ${ombi_data_dir:="/config"} pidfile="${ombi_data_dir}/${name}ombi.pid" pidfile_child="${ombi_data_dir}/${name}_child.pid" command="/usr/sbin/daemon" start_precmd=${name}_precmd ombi_precmd() { if [ ! -d ${ombi_data_dir} ]; then install -d -o ${ombi_user} -g ${ombi_group} ${ombi_data_dir} fi export XDG_CONFIG_HOME=${ombi_data_dir} rc_flags="-r -f -p ${pidfile_child} -P ${pidfile} /usr/local/share/Ombi/Ombi >> /dev/null 2>&1 ${rc_flags} } run_rc_command "$1"
iocage exec ombi chmod u+x /usr/local/etc/rc.d/ombi iocage exec ombi sysrc ombi_enable=YES ombi_data_dir=/config ombi_user=ombi ombi_group=ombi
