Sneffets
- Mar 8, 2017
Hello, I want to start by saying, I have spent ample amount of time doing research on this topic and I have not really found too many people with the same "options" that I have...so I am looking for some good solid opinions or if I am missing something...thank you in advance.
I have two FreeNAS servers, both running 11.1-U6, both are mult-core Xeon Processors, the main "production" one has 96GB of RAM and 6 - 4TB SAS drives (RAIDZ2), SSD Caching, etc...the second one isn't as powerful, 16GB RAM, 4 - 8TB SATA drives (RAIDZ1), SSD cache as well...and I zfs sync the snapshots via a 10GB Mellanox (point-to-point)...so I do have the current dataset on a snapshot(s) on the backup FreeNAS.
The production FreeNAS is running out of space, I am at about 93% capacity and I want to add two more 4TB SAS drives, bringing it to a total of 8 drives...per my research I have discovered (unless I missed something) that I cannot simply "add" two more drives to the existing RAIDZ2, but I could create another VDEV and use that to expand the capacity, BUT since I am running RAIDZ2 adding these drives via a MIRROR (since I only have two more drives) isn't really going to get me the additional space I was looking for....SOOOOOO given that I do have a snapshot copy of the almost 14TB of data...I think my BEST option would be to Destroy the existing Pool, re-create a new one...probably with RAIDZ1 (initially I did not have a backup NAS)...then copy the data (snapshots) back to the Production FreeNAS (this take about 21 hours using nc enabled zfs send/receive)????
IF this is indeed my best option...am I going to have any issues "converting" or importing the snapshot(s) into the live data? I noticed people discussing making a copy of the data and/or importing the snapshot...as I will only have about 7TB remaining once the snapshot(s) are moved over...I would not have enough space to keep the data + snapshots...just trying to verify this process/procedure so I don't lose all of my data, or run into an instance where I have the data, but not enough space to "make" it live. I am pretty sure from what I have read, this should not be an issue, but again...I wasn't really able to find someone doing a snapshot restore from a backup NAS (not at least one that seemed solid enough to gamble my data on).
Any words of wisdom would be greatly appreciated...thanks again for sharing the knowledge!
