Expanding a raidz2 pool and encryption (Panic attack)
Fr33nasnoobi3
So HOPEFULLY this is fixable and i didn't find a bug.... So i had a 6 drive raidz2 (6x4tb drives) setup working fine for a few years it was running out of space and i expanded it with an additional 6x6tb drives ok everything worked fine and dandy for a few months fast forward to me trying to update to freenas 10 to check it out i installed freenas 10 (formated) my boot drives thinking i would just be able to import my volume and go on as normal.... This is where things went south come to find out still a bug (from what i read) with 10 and the importing of encypted volumes sigh* no biggie i think ill just reinstall 9.10 so i do that and go to import the volume like i have done before and.....
  • The following disks failed to attach: gptid/723c9664-e2aa-11e6-81a3-d050992ecffc, gptid/b6362ee9-9e0c-11e5-b673-d050992ecffc, gptid/5d085582-5328-11e4-b620-d050992ecffc, gptid/5c97b2be-5328-11e4-b620-d050992ecffc, gptid/737f80ad-e2aa-11e6-81a3-d050992ecffc, gptid/5e4a6066-5328-11e4-b620-d050992ecffc, gptid/6e92dd63-e2aa-11e6-81a3-d050992ecffc, gptid/6d5a535f-e2aa-11e6-81a3-d050992ecffc, gptid/5de1d537-5328-11e4-b620-d050992ecffc, gptid/5eb1d8e2-5328-11e4-b620-d050992ecffc, gptid/7103a362-e2aa-11e6-81a3-d050992ecffc, gptid/6fc79c28-e2aa-11e6-81a3-d050992ecffc
OH CRAP!!! and if i remember right this is the same error it gave me in freenas 10 when trying to import (before i read there was an issue with it) Bug #19568
So my main question is.... (i mean besides how do i fix this for the love of god all my data is gone) when u expand a volume like i did does it re-key the geil.key file? becuase the file i have downloaded was last modified a day after i got my hard drives from amazon so i assume it asked me to re-download the key or i just did it out of habit. not sure slept a few times since jan 23rd.
So anyone know how i get this damn thing back online? :'( please help!
SweetAndLow
Sweet'NASty
output of zpool status, zpool import and hardware specs please.
m0nkey_
That isn't good. Just to add to @SweetAndLow request, also include the output of camcontrol devlist.
Your best course of recovery is to restore your data from backups.
Fr33nasnoobi3
Hardware specs
https://www.amazon.com/gp/product/B00HIDQG6E/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B008EMA5VU/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
[root@freenas ~]# zpool status
pool: freenas-boot
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
errors: No known data errors
zpool import displays nothing and im to stupid to figure out how to do it from the command line.... cant seem to get a usb key to mount with the geil.key file on it to try....
[root@freenas ~]# camcontrol devlist
<ST4000DM000-1F2168 CC52> at scbus0 target 0 lun 0 (pass0,ada0)
<ST6000VN0041-2EL11C SC61> at scbus1 target 0 lun 0 (pass1,ada1)
<ST4000DM000-1F2168 CC54> at scbus2 target 0 lun 0 (pass2,ada2)
<ST4000DM000-1F2168 CC54> at scbus3 target 0 lun 0 (pass3,ada3)
<ST4000DM000-1F2168 CC52> at scbus4 target 0 lun 0 (pass4,ada4)
<ST4000VN000-1H4168 SC43> at scbus5 target 0 lun 0 (pass5,ada5)
<Marvell Console 1.01> at scbus9 target 0 lun 0 (pass6)
<ST6000VN0041-2EL11C SC61> at scbus10 target 0 lun 0 (pass7,ada6)
<ST6000VN0041-2EL11C SC61> at scbus11 target 0 lun 0 (pass8,ada7)
<ST6000VN0041-2EL11C SC61> at scbus12 target 0 lun 0 (pass9,ada8)
<ST6000VN0041-2EL11C SC61> at scbus13 target 0 lun 0 (pass10,ada9)
<ST4000VN000-1H4168 SC46> at scbus14 target 0 lun 0 (pass11,ada10)
<ST6000VN0041-2EL11C SC61> at scbus15 target 0 lun 0 (pass12,ada11)
<Kingston DataTraveler SE9 PMAP> at scbus17 target 0 lun 0 (pass13,da0)
<Kingston DataTraveler SE9 PMAP> at scbus18 target 0 lun 0 (pass14,da1)
<Kingston DataTraveler 3.0 PMAP> at scbus19 target 0 lun 0 (da2,pass15)
Fr33nasnoobi3
SweetAndLow
Sweet'NASty
When you try and use the GUI to import the pool does it take your key and passphrase or your recovery key?
Fr33nasnoobi3
It doesnt say its wrong but it does say ...
SweetAndLow
Sweet'NASty
Is this with the recovery key or normal key? Sounds like you will be restoring from backup because you can't decrypt your pool.
Fr33nasnoobi3
honestly up until a day or 2 ago when i started researching this i didn't know there was a recovery key i always downloaded the key and saved it.... so does that error mean the key is corrupted?
SweetAndLow
Sweet'NASty
Key isn't corrupt you just messed something up when creating the key or adding the vdev.
Fr33nasnoobi3
So what did i do wrong if everything is truly gone? i used the gui for everything it expanded the data set fine everything was working correctly and im about 99% sure i downloaded another copy of the key...
SweetAndLow
Sweet'NASty
I have no clue what you did. That is a question you have to ask yourself. I can tell you that the key you are trying to use to unlock the volume is probably the wrong one. You should just test it yourself but I did it for you. When I encrypted a pool then added a vdev and did not rekey the pool like required. I could not import the pool using the old key and got the exact error you are seeing. So I suspect you have the original encryption key from the first pool and you did not rekey the system or you are accidentally using the older key.
