'Exclude' syntax for Cloud Sync?
stualden
I'm getting an error when backing up (push sync) using Cloud Sync to BackBlaze B2. Some portions are backing up fine, so I'm trying to narrow the scope of the backup to find the problem area. I thought I would use the Exclude feature to do that, but it doesn't seem to be excluding--when I browse online, the folders I wanted to exclude are still getting copied over.
Could someone please clarify the proper syntax for exclusion, just in case that's my problem? (I can't decipher the rclone documentation.)
Let's say I have a folder
/mnt/Foo
and it contains a folder
/mnt/Foo/Bar
and I want to exclude the Bar folder and everything in it (and beneath it). When push-syncing /mnt/Foo, what would I put on the exclude line? None of the naively "obvious" alternatives work - e.g.,
Bar
Bar/
/mnt/Foo/Bar
/mnt/Foo/Bar/
None of these seems to work. What is the secret syntax???
Thanks,
--Stu
Yorick
Bar/** or some variant thereof would be the choice as per the rclone docs.
stualden
Thank you! A single too-long filename was causing the cloud sync crash.
Liquid3564
Hey, sorry for reviving a very old post. But I have a question. Would /mnt/Foo/Bar/** have the same effect?
And what if the file structure looked like this:
/mnt
/Foo​
/Bar​
/Baz​
/Bar​
Would
Bar/**
then exclude everything in /mnt/Foo/Bar/ AND /mnt/Baz/Bar/ ?
Again sorry for reviving this old post, I just can't seem to understand how this exactly works.
