I am upgrading FreeNAS 9.10 to 11.1 via web interface and getting the following Operational Error. My intent is to upgrade this NAS to the latest version. I cannot access the console nor web interface at this time. 9.10 was stable but had what were deemed innocuous errors in the system log according to the posts I observed. I replaced my Cruzer USB with another but it produced the same innocuous errors. Iconfig output shows link is active and dimes shows all peripherals; keyboard, mouse, USB and Drives up and operational. I do know I can reboot back to 9.10 but would prefer to upgrade. I also get this error in the console output loop, "getty repeating too quickly on /dev/ttyv0, sleeping 30 secs". After 30 seconds, it tries again and fails." The exception error was issued during the reboot of 11.1.
Any advice you can impart on how to proceed from this point would be greatly appreciated. There is a very similar post Jan 20, 2018 for this problem but there was no resolution. Member seeking help was Fred Goran Karlsen. Shall I reinstall from a USB stick with 11.1 and re-load my config file?
Request Method: | GET |
Request URL: | <requested URL is web interface IP address that works with 9.10> |
Software Version: | FreeNAS-11-MASTER-201704201253 (fd84b41) |
Exception Type: | OperationalError |
Exception Value: | no such column: system_settings.stg_sysloglevel |
Exception Location: | ./freenasUI/freeadmin/sqlite3_ha/base.py in locked_retry, line 406 |
Server time: | Sun, 20 Feb 2022 23:51:32 -0500 |
Traceback: File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py" in execute 64. return self.cursor.execute(sql, params) File "./freenasUI/freeadmin/sqlite3_ha/base.py" in execute 424. execute = self.locked_retry(Database.Cursor.execute, query, params) File "./freenasUI/freeadmin/sqlite3_ha/base.py" in locked_retry 406. rv = method(self, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 244. response = middleware_method(request) File "./freenasUI/freeadmin/middleware.py" in process_request 188. language = Settings.objects.order_by('-id')[0].stg_language File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __getitem__ 295. return list(qs)[0] File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __iter__ 256. self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in _fetch_all 1087. self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __iter__ 54. results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py" in execute_sql 835. cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py" in execute 64. return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py" in __exit__ 94. six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py" in reraise 685. raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py" in execute 64. return self.cursor.execute(sql, params) File "./freenasUI/freeadmin/sqlite3_ha/base.py" in execute 424. execute = self.locked_retry(Database.Cursor.execute, query, params) File "./freenasUI/freeadmin/sqlite3_ha/base.py" in locked_retry 406. rv = method(self, *args, **kwargs) Exception Type: OperationalError at / Exception Value: no such column: system_settings.stg_sysloglevel [ code ] Hardware: BIOS P1.90 ASRock ATX DDR3 1333 LGA 1150 Motherboard H97 PRO4 Intel 5 Pentium(R) CPU G3240 RAM @ 3.10 GHz 2 - Kingston RAM @ 4 GB 1600 MHz PC3-12800 DDR3 Non-ECC CL11 DIMM SR x 8 OS drive: SanDisk Cruzer Fit 8 GB USB2.0 Low Profile Flash Drive 6 - Hitachi 2 TB HDS723020BLA642, SATA3 U300 7200 RPM 64MB HD RAIDZ2 FreeNAS 9.10 STABLE
