Configure the NIC using the ifconfig command to dump when I checked my ethernet speed,
media: Ethernet autoselect (100BaseTX <full-duplex>)
copy the file already exits in the 10-12 Mb did not pass the limit, I did a little research and find the information in the link.
http://www.bluemedora.com/blog/correcting-link-speed-negotiation-issues-freenas-9x
But when I try it 1000baseTX value not pull the USB memory from the FreeNAS system crashes and I have to do the installation from scratch. Can you help in this regard
Note: Prior to version could see the value in the 70-80 Mb.
Motherboard details: http://www.intel.com/content/www/us...top-motherboards/desktop-board-d2550mud2.html
4GB Ram
1 +1 TB HDD
4GB Ram
1 +1 TB HDD
[root@freenas ~]# ifconfig
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO>
ether 00:22:4d:a4:79:6e
inet 192.168.1.100 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x8
ether 02:73:f4:a8:70:00
nd6 options=1<PERFORMNUD>
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 200000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:d3:82:00:0a:0a
status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:04:82:00:0b:0a
status: active
