arankaspar1
- Apr 7, 2020
I'm on TrueNAS 12 and the VM runs fine for like a couple weeks or so then continues to log this...
The webGUI page doesn't load anymore at this point, can't ssh either. Rebooting the VM fixes for another couple weeks.
The ESXi gui is functional for the most part. Just takes extremely long to power off VMs and when I try to shutdown the host it sits there indefinitely, have to manually power cycle. Not sure if it's the VM or host at this point but my CIFS and iSCSI are still alive when this happens.
Using an H200 in IT mode Dell R720 backplane is plugged into the PCIe card (H200).
DRAC doesn't like it but it works. I get these errors...
The storage BP1 SAS A cable is not connected, or is improperly connected.
The storage BP1 SAS B cable is not connected, or is improperly connected.
The H200 is configured for PCI pass-through and is assigned to the VM. Works like a champ for about 2 or 3 weeks but I'm
And yes I already have my VM config > storage controller setting set to LSI SAS Logic. (before I installd TrueNAS 12) not sure if this matters.
Considering flashing my H310mini to IT mode and using that instead...
www.reddit.com
Would probably make DRAC happy too.
r/homelab - Flashing the H310 Mono Mini to IT mode
34 votes and 68 comments so far on Reddit
