ESXi 5 and SAS2008 controller in passtrough won't work in freenasn 8.x
rhymer
My system:
MB: SuperMicro X9SCM-F
Controller: LSI 9211-8i in IT-mode.
Installed as an all-in-one box with ESXi 5U1 and FreeNAS 8.2-BETA4 as a virtual machine with the LSI adapter directly available to it in passtrough mode.
The problem that occurs is that during boot FreeNAS hangs with this message:
run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config mps_startup
There is a solution available here:
http://forums.freenas.org/archive/index.php/t-6166.html
It is to disable MSI and MSI-X interrupts. The issue only exist when using FreeNAS in a VM with ESXi 5 but I think this is a common setup. I have seen several others having the same problem with their SAS2008 based cards.
Some googling revealed that there is a LSI maintained driver that can be used instead, it is mpslsi.ko. Has this driver been tested with FreeNAS? Maybe it will solve the problem. I would test it myself but I don't really know how to replace the mps driver in FreeNAS.
Are there any plans to fix FreeNAS so SAS2008 controllers in passtrhough will work out-of-the-box with ESXi 5?
