Estata / External Harddrive and Freenas/Raid
ippikiokami
Hello All!
I have a ts140 that has only rrom for 5 drives and I want to fit 6 in there... I bought a ibm m1015 already but the problem is I don't have enough room in the case. I bought a 5.25 bay converter that takes 2 bays and makes it 3 but... unfortunately that doesn't fit in my case.
Right now I only need space for 1 more drive but it seems like I'll have to figure out a way to attach it externally.
Any suggestions or successes? I would even switch the case but I've read this motherboard isn't very standard so it'll be hard to find a case for it too.
Thanks
marbus90
Last time I looked that mobo is mATX with an ATX PSU. Should fit in any other case just fine. Only issue could be the LEDs and the Power Switch, but I'm sure you can find adapters for that if you need them.
