errors rcone syncing with onedrive
h4ns
I use freenas, latest version and have Z2 pool with datasets configured for windows shares and smb shares.
I set-up cloud credentials for onedrive, then set-up pull sync with cloud sync tasks with schedule every hour.
First sync looked like it went OK, but every other reported errors...
FAILED:RCLONE
and from log...
Failed to copy: failed to open source object: 400 Bad Request:
Can't store file with control characters: "01 Backup/Luj/05 Documents (OneDrive+2TB-travanj 2015)/Fearh/ISTRIA EX/NAMJE\u007fTAJ 3D/POLICE A-B-N 02.pdf"
My language is Croatian, and files have croatian characters.
In total I had 74 errors in every sync since the first one.
I can't remove the special characters from names, is there a setting in freenas to mitigate this problem?
Thanks
D
dlavigne
Guest
Please create a feature request at bugs.ixsystems.com and post the issue number here.
