Errors after upgrade to Truenas 13
andrema2
Hi
After upgrading to TrueNas13 coming from 12.8 I'm seeing these errors below
collectd 1487 - - cannot get CTL max ports
collectd 1487 - - Initialization of plugin `ctl' failed with status -1. Plugin will be unloaded.
collectd 1487 - - Error: one or more plugin init callbacks failed.
daemon 1704 - - 2022-05-12 16:54:47,031:wsdd WARNING(pid 1705): no interface given, using all interfaces
Everything is running fine. I don't know what does errors mean.
mav@
I don't know what is the last message, but the first three likely just mean that you are not using iSCSI. Probably just a noise that should be muted one day. Please create a ticket.
macmuchmore
I created a ticket with this issue (the same error is generating when trying to attach a 2nd drive to the boot pool, though it may be unrelated to the attach activity). It is NAS-116168
Rastan
Got the same error message (using TrueNAS Core 13). After a couple of minutes my truenas restarted.. Entered the following (in terminal):
service wsdd onestop
After this command my truenas is working fine again...
anodos
Sambassador
If wsdd is causing issues you can disable from the GUI in the webui Network->Global Configuration.
profwalken
on a fresh TN13 install I get same kind of messages (srv name removed on code pasted)
 1 2022-05-18T15:30:18.952460+02:00  collectd 38148 - - cannot get CTL max ports
 syslog-ng[38211]: syslog-ng starting up; version='3.35.1'
 kernel: pid 1132 (syslog-ng), jid 0, uid 0: exited on signal 6 (core dumped)
1 2022-05-18T16:28:13.530132+02:00 collectd 39000 - - cannot get CTL max ports
1 2022-05-18T16:28:13.530179+02:00  collectd 39000 - - Initialization of plugin `ctl' failed with status -1. Plugin will be unloaded.
1 2022-05-18T16:28:13.548393+02:00 collectd 39000 - - Error: one or more plugin init callbacks failed.
1 2022-05-18T16:28:16.703613+02:00 daemon 39095 - - 2022-05-18 16:28:16,703:wsdd WARNING(pid 39096): no interface given, using all interfaces
mha
Hi
@andrema2: have you created a ticket yet? Please let me know if not, then I'll do it. NAS-116168 seems to address a different issue.
I am seeing nearly same thing as you and @profwalken (different order of messages) after updating to 13.0. I'm wondering if this is really two problems. One with wsdd and the other with ctl.
@mav@, @anodos please advise if this should be covered in two issues.
May 28 12:51:04 2022-05-28T12:51:04.503541+02:00 daemon 1453 - - 2022-05-28 12:51:04,446:wsdd WARNING(pid 1454): no interface given, using all interfaces
May 28 12:51:04 2022-05-28T12:51:04.616671+02:00 collectd 1459 - - cannot get CTL max ports
May 28 12:51:04 2022-05-28T12:51:04.616722+02:00 collectd 1459 - - Initialization of plugin `ctl' failed with status -1. Plugin will be unloaded.
May 28 12:51:04 2022-05-28T12:51:04.630337+02:00 collectd 1459 - - Error: one or more plugin init callbacks failed.
paradoxiom
I just noticed this for the first time today, also on 13, googled it, found this. So seems like a bug or something with the new version. things seem to be working fine here too.
Koen_Oostende
I get that error when I power up a backup enclosure array that has exported pools. If I import the pools on that array everything works fine.
 Jun 11 17:09:41 freenas 1 2022-06-11T17:09:41.923636+02:00 freenas.local collectd 28149 - - cannot get CTL max ports
Jun 11 17:09:41 freenas 1 2022-06-11T17:09:41.923649+02:00 freenas.local collectd 28149 - - Initialization of plugin `ctl' failed with status -1. Plugin will be unloaded.
Jun 11 17:09:41 freenas 1 2022-06-11T17:09:41.941418+02:00 freenas.local collectd 28149 - - Error: one or more plugin init callbacks failed
TrueNAS-13.0-RELEASE
