SOLVED Error when upgrade or install fresh chart
Beliall
I'm totaly lost.
I haven't touch truenas for a while.
Some app stop running correctly so now i need to fix them.
I'm running a simple media player apps list (radarr,Flare solver, jackett,qbitt, plex).
Since the feature : "enable host path safety check" i begin to encounter some trouble with radarr ...
I started to disable this option, but its getting worse week after week.
In the end i stoped all chart but plex and qbittorrent.
Im here to try to fix it all.
First step:
-Remove my smbshare ( they was used as host path in radarr,qbitt,plex etc etc)
-enable the host path safety check
-check update, im in 22.12.4.2 (i don't know if i should go to cobia or not)
-remove all old operators
But,
I can't upgrade or install fresh chart or operator
I got this error :
Error:
[EFAULT] Failed to upgrade chart release:
Error: UPGRADE FAILED: template: qbittorrent/templates/common.yaml:11:3: executing "qbittorrent/templates/common.yaml" at < include "tc.v1.common.loader.apply" . >:
error calling include: template: qbittorrent/charts/common/templates/loader/_apply.tpl:47:6: executing "tc.v1.common.loader.apply" at : error calling include: template: qbittorrent/charts/common/templates/spawner/_pvc.tpl:25:10: executing "tc.v1.common.spawner.pvc" at : error calling include: template: qbittorrent/charts/common/templates/lib/storage/_validation.tpl:18:43: executing "tc.v1.common.lib.persistence.validation" at <$objectData.static.mode>: nil pointer evaluating interface {}.mode
Or
Error:
[EFAULT] Failed to install chart release:
Error: INSTALLATION FAILED: template: prometheus-operator/templates/common.yaml:8:3: executing "prometheus-operator/templates/common.yaml" at < include "tc.v1.common.loader.apply" . >:
error calling include: template: prometheus-operator/charts/common/templates/loader/_apply.tpl:47:6: executing "tc.v1.common.loader.apply" at :
error calling include: template: prometheus-operator/charts/common/templates/spawner/_pvc.tpl:25:10: executing "tc.v1.common.spawner.pvc" at :
error calling include: template: prometheus-operator/charts/common/templates/lib/storage/_validation.tpl:18:43: executing "tc.v1.common.lib.persistence.validation" at <$objectData.static.mode>: nil pointer evaluating interface {}.mode
Every hints are appreciated.
Regards
Sorry for my bad english or the miss of information or if it's obvious
Gontran
Beliall
I Guess i have a piece of answer:
Transition Notice: Ending support for TrueNAS SCALE Bluefin (22.12)
Please note, we will be ending support for TrueNAS SCALE Bluefin 22.12.X starting today on 19 December 2023. To continue receiving support and updates in the New Year, we encourage users to upgrade their systems to TrueNAS SCALE Cobia (23.10), which released it's first update to 23.10.1 on December 19th 2023. We have a large community who can assist you through this important transition on our Discord with channels for #truenas-scale and #scale-apps.
