Using TrueNAS Scale 22.02.3. I'm trying to create a Cloud Sync task using a Backblaze account. I created the necessary keys and copied them from the Backblaze account to the cloud credentials area. I verified 3 times the keys are correct. I am getting an error: [EFAULT] Network activity "Cloud sync" is disabled. In the more info area, it says:
I got the same error in 22.02.1 so upgrading did not resolve the issue. I can't find anywhere that might have a setting to enable cloud sync, so I don't understand the error.
Thanks
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 176, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1293, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/cloud_sync.py", line 606, in verify await self.middleware.call("network.general.will_perform_activity", "cloud_sync") File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1344, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1293, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/network_/activity.py", line 54, in will_perform_activity raise CallError(f'Network activity "{self.activities[name]}" is disabled') middlewared.service_exception.CallError: [EFAULT] Network activity "Cloud sync" is disabled
Thanks
