ERROR Setting up email notification.
Mkubiak402
Setting up email notification with my Gmail acount i get this error. in TrueNAS SCALE
Error: [EFAULT] Failed to send email: Unable to find the server at www.googleapis.com
i have tried 3 difrent Email accounts and looking around some one was told a guy to Telnet to Gmail to test for a blocked port and i got though just fine.
I'm kind of lost here.
Heracles
You did your test from a Windows client, not from your TrueNAS server.
It is your TrueNAS server who has the problem, so you must re-do that test from there instead. Pretty sure that test will fail and we will see from that error message what it's all about.
Mkubiak402
ok right now i only have access to the WEB UI till i get home.
i dont know how to do that test with the WEB UI
Heracles
You can use the shell prompt offered in the WebUI for such a test. The other option is to SSH in the box.
Heracles
You open the shell and you type your telnet command just like you did in Windows...
Mkubiak402
thats what i did it was a no go...
looks like i need to get root or admin privileges to install it.. ill to look up how to do that.
Heracles
Are you using Core or SCALE ? Here, I use Core and telnet is present by default...
Mkubiak402
Got it working i think having 4 ports Bridged togater was messing some thing up with the Email notifications
i all so was reading some other people having the same problum when running link aggregation.
so it seems some thing brakes when doing that.
