jerryjharrison
- Jan 15, 2014
I am really struggling with this one. I have several jails with different applications installed showing the same error. This leads me to believe that it is something in the fstab config, but I can't find the error.
I have a newly created zfs dataset on the host located at /mnt/zpool1/plexmedia
I have an iocage jail, created with:
I then created a single FSTAB entry. using the command:
The results from
I then get an error when starting the jail:
The only logical thing to do is go create the missing directory:
Jail now starts
The very next command is a restart of the jail and I get the error:
If I comment out the FSTAB entry, the jail starts normally. If I uncomment the entry, the error reappears immediately. (no clean start)
If the HOST is rebooted, the jail starts normally one time, and then upon restart of the jail, the error prevents the jail from starting.
There is clearly a process that is using the resource, but I cannot determine what is locking it.
iocage create --name "mainplex" -r 11.1-RELEASE ip4_addr="vnet0|10.0.1.71/24" vnet="on" allow_raw_sockets="1" defaultrouter="10.0.1.1" boot="on" host_hostname="mainplex"
iocage fstab -a mainplex '/mnt/zpool1/plexmedia /mnt/plexmedia nullfs rwx 0 0'
The results from
iocage fstab -l mainplex
| 0 | /mnt/zpool1/plexmedia /mnt/iocage/jails/mainplex/root/mnt/plexmedia nullfs rwx 0 0 |
root@corral1:/ # iocage start mainplex * Starting mainplex + Start FAILED jail: mount.fstab: /mnt/iocage/jails/mainplex/root/mnt/plexmedia: No such file or directory
mkdir /mnt/iocage/jails/mainplex/root/mnt/plexmedia root@corral1:/ # ls /mnt/iocage/jails/mainplex/root/mnt plexmedia
Jail now starts
root@corral1:/ # iocage start mainplex * Starting mainplex + Started OK + Configuring VNET OK + Starting services OK
root@corral1:/ # iocage restart mainplex * Stopping mainplex + Running prestop OK + Stopping services OK + Tearing down VNET OK + Removing jail process OK + Running poststop OK * Starting mainplex + Start FAILED mount_nullfs: /mnt/iocage/jails/mainplex/root/mnt/plexmedia: Resource deadlock avoided jail: /sbin/mount -t nullfs -o rwx /mnt/zpool1/plexmedia /mnt/iocage/jails/mainplex/root/mnt/plexmedia: failed
