DeWebDude
- Nov 2, 2015
Hello All,
I'm running FreeNAS-9.10.1-U3 (d985cd1) it has been running well, but in the past couple months I have been getting a corruption issue with of all things the USB Drive.
Error message is below.
I do have some older backups of the configuration as well as being able to take a current configuration backup.
I did try some methods for correcting the issue, but those didn't work and the message keeps coming.
My question is what is the safest way to repair the situation, do I simply pop in a new USB drive with the same or newer version?
I just need to insure I protect the data of course.
I appreciate any assistance or pointing to a well written doc on how to approach the issue.
Thanks!
Thanks!
Checking status of zfs pools: NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT VOL1 8.16T 985G 7.19T - 48% 11% 1.00x ONLINE /mnt freenas-boot 15G 1.71G 13.3G - - 11% 1.00x ONLINE - pool: freenas-boot state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 0 in 0h2m with 0 errors on Mon Jun 18 03:47:35 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/33c6a617-31b0-11e6-b824-78e3b510a9c8 ONLINE 0 0 38 errors: No known data errors -- End of daily output --
