XTREEMMAK
- Feb 8, 2016
Ok so I'm a little confused.
Mind you I'm a FreeNAS and FreeBSD noobie so forgive my ignorance. I got an email update as soon as I got home in regards to the FreeNas Boot volume containing an error. I did some searching on the forum and ran zpool status -v freenas-boot.
Here's what I got:
This happened after my scrub. Funny I'm getting an error after just having the server set up for 3 months x_X. In any case, I'm running FreeNAS off a Verbatim 16GB USB drive:
http://www.amazon.com/gp/product/B004BLIQE6/?tag=ozlp-20
Now I'm not sure but, I went to advanced and backed up my db config successfully (I'll look up to see if there is anything else I'll have to do to backup my config). Should I just go ahead and try to reinstall FreeNAS on the USB?
I also read it might just be better to pick something like this up and install on it?
http://www.amazon.com/dp/B00SZPVN44/?tag=ozlp-20
Here's what I got:
pool: freenas-boot state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 0 in 0h4m with 0 errors on Tue Mar 1 20:34:28 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/4209fc6a-c971-11e5-bb22-bc5ff4c7d6f3 ONLINE 0 0 1 errors: No known data errors [root@LunchBunchHQ ~]#
