Thomymaster
 - Apr 26, 2013
Hi
With my 9.2.6.1-RELEASE i wanted to setup an rsync task to my backup server. I did this yesternday and noticed that nothing was synced.
So i looked in the log and saw:
Jul 21 20:00:00 storage rsync: No ECDSA host key is known for backup.kunst-und-kuriosa.de and you have requested strict checking.^M
Jul 21 20:00:00 storage rsync: Host key verification failed.^M
Jul 21 20:00:00 storage rsync: rsync: connection unexpectedly closed (0 bytes received so far) [sender]
Jul 21 20:00:00 storage rsync: rsync error: error in rsync protocol data stream (code 12) at io.c(605) [sender=3.0.9]
I then manually tried to connect to backup via SSH and it asked me to save the host key. I entered "yes" (i already exported my FreeNAS pubkey to backup, so i didn't need a password) but as soon as i terminated the connection and restartet it, i was again asked.
When i did a
mount -o rw /
before connecting it made the FreeNAS rootfs writeable and the host key was saved.
Is this a normal behaviour or can this be fixed in some way?
Cheers
Thomy
When i did a
mount -o rw /
Cheers
Thomy
