mgb
- Aug 10, 2015
Greetings humans,
I'm in the "requirements gathering" stage of a new enterprise build and I'd like some feedback / recommendations on the hardware I'm looking at purchasing.
Use Case: Serve around ~10 ESXi VMs over iSCSI and provide SMB shares for ~40 Win7 workstations (corporate file share + workstation backups).
I've narrowed my options down to the following:
Chassis (option 1): SM CSE-826BE2C-R920LPB 2U 12-bay (Dual Expanders, 920W Redundant PSUs)
Chassis (option 2): SM CSE-846BE26-R920B 4U 24-bay (Dual Expanders, 920W Redundant PSUs)
Motherboard (UP): SM X10SRL-F
Motherboard (DP): SM X10DRi
CPU(s): 1x (or 2x) Intel Xeon E5-2620v3 (Hex-core, 15M Cache, 2.40 GHz)
HBA: 1x LSI SAS 9207-8i
RAM: (..to be determined...)
OS: 2x (or 4x) SM SuperDOM Flash (64GB)
ZIL: 1x Intel DC S3700 100GB
L2ARC: 1x Intel DC S3500 480GB
Data: 4x HGST Ultrastar 7K400 SAS2 4TB (1x3-deep mirror + 1 hot spare)
My thoughts...
Chassis: As of now, we're using 2x3-deep mirrors with 2TB WD RE4 HDDs (~2TB consumed out of ~4TB usable). If I opt for the 12-bay system, I could get a maximum ~12TB (3x3-deep mirrors + 3 hot spares). I'm of the paranoid type so I prefer 3-way mirrors + 1 hot spare / vdev. A 24-bay system would give me lots of room to grow.
Motherboard: Since our workload is quite lite, I'm leaning towards the UP board. The overall price difference of the DP board + an extra CPU is ~$730. The only benefits I can think of is extra RAM slots + 12-cores (24-threads) over 6-cores (12-threads). I don't think our workload warrants this price increase.
ZIL: I've considered mirroring the ZIL but since the chassis would use SAS2 drives + dual expanders, my thoughts are to keep the front bays reserved only for data drives and use the optional 2x2.5" hot-swappable cage in the rear for the ZIL + L2ARC.
Data: I understand the benefits of dual-ported SAS drives, but is this really necessary unless your using dual expanders?
An alternative would be to opt for the 4U / 24-bay with either a single expander (or direct cabling) and use SATA3 data drives. Then I would put all drives (OS + ZIL + L2ARC) in the front bays and I could mirror the ZIL + have the option of concatenating multiple L2ARC drives. I've heard that expanders can go bad, so maybe I'd be better off with direct cabling + an extra HBA (I have no experience with expanders).
Am I going overboard here with this CPU + Motherboard combo?
Any feedback is greatly appreciated!
Thanks,
--mgb
My thoughts...
Thanks,
--mgb
