brandonpoc
- Mar 26, 2013
Emergency over here!
I have a volume, called "SSD", consisting of two 60GB SSDs; I created the volume with one SSD (/dev/ada0), and I added the other SSD (/dev/ada5) shortly thereafter and expanded the volume to include the new SSD. I had been using it fine with encryption for a week now, until I just rebooted and am now unable to unlock the volume! I know the passphrase is correct; so, I tried the recovery key to no avail. Nothing is working to unlock the volume! Everything is still in order -- the first SSD is ada0, the second is ada5.
What in the world happened here? Could adding the second SSD have screwed something up? What can I do? Is it possible to remove the second SSD and have it work? Should I expect my primary volume for storage (3x3TB, striped) to fail on me like this as well?
Thanks in advance,
Brandon
My system:
Thanks in advance,
Brandon
My system:
- FreeNAS 8.3.1 64-bit, AMD64 (Phenom II x2), 16GB DDR3 memory
- Volume 1: 3x3TB HDD (Striped, Encrypted) (on-board SATA)
- Volume 2: 2x60GB SSD (striped, encrypted) (PCI SATA)
- Unused: 500GB SSD
