Hi guys,
So I'm now in a situation where multipathing would be of great use and would more than likely solve a few issues I'm having. First off, I DO have the equipment to support this, I have a backplane that has two LSI 9300-8i connected. My issue is that I have 6 drives but FreeNAS is seeing 12.
Now normally, I would not disrupt a working setup but it seems there are conflicts once every few weeks. The last incident was the last straw, I had to rebuild a drive because a SMART test failed and the raid degraded. To be clear it did not fail, it could not start a SMART test as it was already being performed by the other controller on the same drive and couldn't get the handle as per the log.
What is the safest way to create the multipathing after the pool exists? Export and reimport after using gmultipath? I tried a few things and had to use gpart recover to basically undo my crude attempt.
Any insight would be greatly appreciated. Thanks!
