- Jan 20, 2017
With the newest chart version of 2.0.5 the GIDLIST environment variable (value: 44,107) leads to an error:
"error FAILED
[EFAULT] Failed to update App: Error: UPGRADE FAILED: template: emby/templates/common.yaml:6:38: executing "emby/templates/common.yaml" at : error calling include: template: emby/templates/_emby.tpl:31:23: executing "emby.workload" at <.Values.embyGPU>: can't evaluate field Values in type []interface {} "
This is on TrueNAS SCALE 23.10.2. All worked fine with 2.0.4. This is required to hand over the GPU for transcoding. Now, it doesn't work anymore.
I had to rollback to 4.8.1.0_2.0.3 as for some reason 4.8.3.0_2.0.4 couldn't be found.
While we're at it. Could we make this like automatic, when selecting a GPU (i.e., in the background, without user intervention, adding the required GIDLIST 44,107 to make the GPU work)? I mean, it doesn't work without it, at all. Why not remove this failure mode for users?
Thanks!
"error FAILED
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 559, in do_update
await self.middleware.call('chart.release.helm_action', chart_release, chart_path, config, 'update')
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1353, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 49, in helm_action
raise CallError(f'Failed to {tn_action} App: {errmsg}')
middlewared.service_exception.CallError: [EFAULT] Failed to update App: Error: UPGRADE FAILED: template: emby/templates/common.yaml:6:38: executing "emby/templates/common.yaml" at <include "emby.workload" $>: error calling include: template: emby/templates/_emby.tpl:31:23: executing "emby.workload" at <.Values.embyGPU>: can't evaluate field Values in type []interface {}
Thanks!
