Either Drive Dying or FreeNAS is not configured properly..
darkryoushii
Hey there,
My NAS hardware info is in the signature below so I won't bore you with the details. Basically I think one of those drives is dying or my FreeNAS settings are incorrect. Every 5 - 10 seconds I hear a crunching sound from one of the drives, but it's like a deep grind and only for half a second or so. I tried to record it but all I got was static from the fans next to it. Tomorrow I will record a better version.
So my question to you is, is my drive dying (it seemed to only start when I rebuilt a pool and doesn't do it when I'm shutting down the nas making me think it's a process doing something weird) and how can I tell what drive is dying, what tools can I run to keep it in healthy shape and will I get a fair warning that the drive is on it's way out or will it just cark it and the pool will go offline.
Thanks in advance,
DarkRyoushii
warri
Run a long smart test on the drive and post back the results. But generally weird sounds coming from the HDD are a good indicator that something is wrong with the drive.
darkryoushii
thanks for the reply, is there a gui way to force the test or a command to run? and how do I view the results when completed?
warri
I'm not sure if there is a functionality in the GUI, I think you can just schedule regular smart tests there (which also is a very good idea).
Here is a guide for the shell.
Start a long smart test with:
smartctl -t long /dev/adaX
Where X is the number of the drive. If you don't know the number, use this command to get a list of all devices:
camcontrol devlist
When the test is finished after some hours you can access the results with:
smartctl -q noserial -a /dev/adaX
Alternatively you can do a short test first ('-t short' instead of '-t long'), which will finish within minutes.
darkryoushii
Thanks again. After running long smart test on all drives they are all returning
# 1  Extended offline    Completed without error       00%       696         -
including the 2.5" plugins drive I have in there. :\
warri
Can you post all the details from the output?
darkryoushii
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p6 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model:     Hitachi HDS723030BLE640
Firmware Version: MX6OAAB0
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Mon Mar 25 11:01:45 2013 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x85)	Offline data collection activity
					was aborted by an interrupting command from host.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(22222) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 371) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   140   140   054    Pre-fail  Offline      -       68
  3 Spin_Up_Time            0x0007   140   140   024    Pre-fail  Always       -       401 (Average 415)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       213
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   124   124   020    Pre-fail  Offline      -       33
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       698
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       53
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       276
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       276
194 Temperature_Celsius     0x0002   214   214   000    Old_age   Always       -       28 (Min/Max 21/43)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
ATA Version is:   8
Local Time is:    Mon Mar 25 11:01:55 2013 EST
					been run.
					command.
					power-saving mode.
  2 Throughput_Performance  0x0005   140   140   054    Pre-fail  Offline      -       69
  3 Spin_Up_Time            0x0007   139   139   024    Pre-fail  Always       -       405 (Average 420)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       207
  8 Seek_Time_Performance   0x0005   121   121   020    Pre-fail  Offline      -       34
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       271
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       271
194 Temperature_Celsius     0x0002   200   200   000    Old_age   Always       -       30 (Min/Max 22/48)
No Errors Logged
ATA Version is:   8
Local Time is:    Mon Mar 25 11:02:01 2013 EST
					been run.
data collection: 		(22078) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 368) minutes.
  2 Throughput_Performance  0x0005   139   139   054    Pre-fail  Offline      -       70
  3 Spin_Up_Time            0x0007   139   139   024    Pre-fail  Always       -       405 (Average 418)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       208
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       270
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       270
No Errors Logged
ATA Version is:   8
Local Time is:    Mon Mar 25 11:02:07 2013 EST
					been run.
data collection: 		(22365) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 373) minutes.
  2 Throughput_Performance  0x0005   139   139   054    Pre-fail  Offline      -       71
  3 Spin_Up_Time            0x0007   137   137   024    Pre-fail  Always       -       426 (Average 410)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       206
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       267
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       267
194 Temperature_Celsius     0x0002   222   222   000    Old_age   Always       -       27 (Min/Max 20/43)
No Errors Logged
ATA Version is:   8
Local Time is:    Mon Mar 25 11:02:13 2013 EST
					been run.
data collection: 		(24086) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 402) minutes.
  3 Spin_Up_Time            0x0007   140   140   024    Pre-fail  Always       -       399 (Average 420)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       204
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       266
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       266
194 Temperature_Celsius     0x0002   214   214   000    Old_age   Always       -       28 (Min/Max 22/44)
No Errors Logged
Model Family:     SAMSUNG SpinPoint M5
Device Model:     SAMSUNG HM160HI
Firmware Version: HH100-08
User Capacity:    160,041,885,696 bytes [160 GB]
Sector Size:      512 bytes logical/physical
ATA Version is:   7
ATA Standard is:  ATA/ATAPI-7 T13 1532D revision 0
Local Time is:    Mon Mar 25 11:02:18 2013 EST
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					been run.
data collection: 		(   55) seconds.
					command.
					power-saving mode.
recommended polling time: 	 (   2) minutes.
recommended polling time: 	 (  55) minutes.
SCT capabilities: 	       (0x003f)	SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   100   100   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0007   252   252   025    Pre-fail  Always       -       1937
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1472
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       1
  7 Seek_Error_Rate         0x000e   252   252   051    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   084   084   000    Old_age   Always       -       8207
 10 Spin_Retry_Count        0x0032   100   100   051    Old_age   Always       -       10
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       911
191 G-Sense_Error_Rate      0x0032   099   099   000    Old_age   Always       -       10355
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       463
194 Temperature_Celsius     0x0022   169   067   000    Old_age   Always       -       23 (Min/Max 11/57)
195 Hardware_ECC_Recovered  0x001a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   252   252   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x000a   100   100   000    Old_age   Always       -       0
201 Soft_Read_Error_Rate    0x0032   252   252   000    Old_age   Always       -       0
223 Load_Retry_Count        0x0032   098   098   000    Old_age   Always       -       2021
225 Load_Cycle_Count        0x0032   060   060   000    Old_age   Always       -       406981
No Errors Logged
# 1  Extended offline    Completed without error       00%      8200         -
# 2  Short offline       Completed without error       00%      8199         -
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
    1        0        0  Completed [00% left] (0-65535)
warri
The Hitachi drives look fine.
Only the Samsung could have an issue: 1 reallocated sector and a non-empty G-Sense Error Rate (according to Wikipedia: The count of errors resulting from externally induced shock & vibration.). This drive is probably not part of your pool anyway, so I wouldn't worry to much.
If your pool offers some redundancy, you are probably OK for now. Just keep an eye (and ear) on the drive producing the sounds and configure regular SMART tests and scrubs so that you'll notice any degradation early on.
Update: Maybe you could try to find out which drive exactly produces the sound? Either by unplugging one drive at a time or listening more closely? If you plan on doing that, I'd start with the 2,5" disk.
One thing did catch my eye.
Holy freakin' crap! I've never seen that value that high.. ever. Considering the other drives are all zero, I think that's the drive with the problems.
From some small google search that value is the number of times the drive has been parked. That's an extremely large value! I'm wondering if the drive is having an issue with the firmware or otherwise that is making it think it should park and unpark so frequently. WD Green drives can suffer this kind of fate if you don't use the WDIDLE tool, but the 160GB is a Samsung, so I have no advice to provide at all.
But I think that's the drive you are hearing park and unpark. The drive itself may not be bad at all, but if its racking up park/unparkss that fast I have to wonder how long that drive will last before it becomes unreliable. I've never owned any Samsung drives, so I can't provide any additional assistance. I'd try Googling around and see if anyone else has solved this problem(or had this problem). Check for firmware updates(if possible), your SATA controller settings, and definitely backup the data on that drive. :P
