D
Deleted47050
Guest
So here is the summary of the situation: some time ago both of the drives in my mirror started dying, so I replaced them and, while I was at it, I also replaced them with bigger drives. Before the upgrade, my two drives were mapped as ada0 and ada1.
Because I did the upgrade by using a third mirror, I initially added my first drive (ada2) to replace ada0, and then the second drive (ada3), to replace ada1. Everything worked fine and my pool is up and running now.
After rebooting the system after the upgrade, however, I noticed that my two new drives were not mapped to ada2 and ada3 anymore, but are now mapped as ada0 and ada1. This makes perfect sense (they are, after all, the replacements for old drives ada0 and ada1), however, looking at this post, it looks like this should only happen when there is an issue.
So I am a bit confused now: is this expected behavior or not, in the contest of a replacing disks using a third mirror?
