E3C224D2I repair ?
ChuckM
I built a ASRock E3C224D2I based box about 4 years ago and it's been working perfectly until last week, but now it won't turn on. I've done the usual trouble shooting and it's definitely the motherboard and it appears to be a power supply issue. I have a nice green LED and +5V standby, but there's no voltage on the on/off switch or anywhere else that I can find. The management Ethernet no longer lights up and I don't see it on my network.
I've looked for a new motherboard, but it's too old and the Mini ATX form factor and LGA1150 socket rules out everything I can find.
So ... does anyone know of anyone doing component level motherboard repairs? Or any place I might find a used motherboard (I've already tried ebay)?
Thanks!
Skip
Inxsible
Time for a new board & a new case, I'd say !
You'd find plenty in the m-ATX format -- X10SLH-F would be able to use the same CPU etc. You could transfer the whole system over and not miss a beat !
in cases: Node804, Define R7, any rackmount etc.
ChuckM
Nice MB, but micro ATX, not Mini ATX. I ended up buying a used Dell T-20. It works, but I'm not trilled, lots of wasted space and they only bring out 4 of the 6 SATA ports. That was all I needed, but still!
Skip
