NeverSimple
- Jul 27, 2011
I've been using FreeNAS since the 8.0 beta's and now using 8.0.2 (amd64). Getting e-mail from the FreeNAS box has been a challenge. Although lots of work seems to have been done on the e-mail system, it is still not working for me. I've followed the setup guide without problems, but keep getting:
when trying to send a test message (in /var/log/maillog) and the message is not send. I think in 8.0.1-BETA4 or 5 this was the same but IIRC e-mail reports from the FreeNAS box did work. Now nothing is coming from it.
Because I made it a habit to manually check the log files every few days, this hasn't been high on my priority list, thinking it would be solved somewhere down the road.
Has it been 'solved' and am I using a wrong configuration? If it should work, could anyone point me in the right direction?
Richard
TypeError: character mapping must return integer, None or unicode
Richard
