i have an DS4243 with two IOM6 modules installed.
The diskshelf is connected to an LSI 9300-8e where i today upgraded the firmware to 16.00.01.00 via DOS.
My second IOM6 module arrived today too but i can't get multipathing up and running.
The
Both IOM6 modules are connected to the LSI 9300-8e.
I also don't have a "View Multipath" button in the Web-GUI
Both IOM6 modules are working and both ports on the 9300-8e functioning well.
My goal is to create an Active/Active connection to split the load between the IOM6 modules and get higher read and write speeds.
The
camcontrol devlist just shows the 24 disks of the 24 installed in the shelf.Both IOM6 modules are connected to the LSI 9300-8e.
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 8 lun 0 (da2,pass3)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 9 lun 0 (da3,pass4)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 10 lun 0 (da4,pass5)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 11 lun 0 (da5,pass6)
<NETAPP X412_S15K7560A15 NA06> at scbus3 target 12 lun 0 (pass7,da6)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 13 lun 0 (pass8,da7)
<NETAPP X412_S15K7560A15 NA08> at scbus3 target 14 lun 0 (pass9,da8)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 15 lun 0 (pass10,da9)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 16 lun 0 (pass11,da10)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 17 lun 0 (pass12,da11)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 18 lun 0 (pass13,da12)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 19 lun 0 (pass14,da13)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 20 lun 0 (pass15,da14)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 21 lun 0 (pass16,da15)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 22 lun 0 (pass17,da16)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 23 lun 0 (pass18,da17)
<NETAPP X412_S15K7560A15 NA06> at scbus3 target 24 lun 0 (pass19,da18)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 25 lun 0 (pass20,da19)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 26 lun 0 (pass21,da20)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 27 lun 0 (pass22,da21)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 28 lun 0 (pass23,da22)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 29 lun 0 (pass24,da23)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 30 lun 0 (pass25,da24)
<NETAPP X412_HVIPC560A15 NA03> at scbus3 target 31 lun 0 (pass26,da25)
<NETAPP DS424IOM6 0180> at scbus3 target 36 lun 0 (ses0,pass27)
mpr0: <Avago Technologies (LSI) SAS3008> port 0xc000-0xc0ff mem 0xfc990000-0xfc99ffff,0xfc940000-0xfc97ffff irq 10 at device 6.0 on pci0
mpr0: IOC in fault state 0x0
mpr0: Firmware: 16.00.01.00, Driver: 18.03.00.00-fbsd
mpr0: IOCCapabilities: 7a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc,FastPath,RDPQArray>
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a48e
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000a> enclosureHandle<0x0002> slot 0
mpr0: At enclosure level 0 and connector name ( )
mpr0: SAS Address from SAS device page0 = 5000cca02ad948f2
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000b> enclosureHandle<0x0002> slot 1
mpr0: SAS Address from SAS device page0 = 5000cca02ad964a2
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000c> enclosureHandle<0x0002> slot 2
mpr0: SAS Address from SAS device page0 = 5000cca02ad9b776
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000d> enclosureHandle<0x0002> slot 3
mpr0: SAS Address from SAS device page0 = 5000c5006800752e
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000e> enclosureHandle<0x0002> slot 4
mpr0: SAS Address from SAS device page0 = 5000cca02ad192ce
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x000f> enclosureHandle<0x0002> slot 5
mpr0: SAS Address from SAS device page0 = 5000c5007156f1a6
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0010> enclosureHandle<0x0002> slot 6
mpr0: SAS Address from SAS device page0 = 5000cca02ad193d6
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0011> enclosureHandle<0x0002> slot 7
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ac7a
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0012> enclosureHandle<0x0002> slot 8
mpr0: SAS Address from SAS device page0 = 5000cca02ad93e9a
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0013> enclosureHandle<0x0002> slot 9
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a326
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0014> enclosureHandle<0x0002> slot 10
mpr0: SAS Address from SAS device page0 = 5000cca02ad193fe
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0015> enclosureHandle<0x0002> slot 11
mpr0: SAS Address from SAS device page0 = 5000cca02ad1acaa
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0016> enclosureHandle<0x0002> slot 12
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ecb6
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0017> enclosureHandle<0x0002> slot 13
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ab8e
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0018> enclosureHandle<0x0002> slot 14
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ae32
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0019> enclosureHandle<0x0002> slot 15
mpr0: SAS Address from SAS device page0 = 5000c5007e101026
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001a> enclosureHandle<0x0002> slot 16
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a3ce
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001b> enclosureHandle<0x0002> slot 17
mpr0: SAS Address from SAS device page0 = 5000cca02ad19b6e
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001c> enclosureHandle<0x0002> slot 18
mpr0: SAS Address from SAS device page0 = 5000cca02ad1adc2
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001d> enclosureHandle<0x0002> slot 19
mpr0: SAS Address from SAS device page0 = 5000cca02ad1eaa6
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001e> enclosureHandle<0x0002> slot 20
mpr0: SAS Address from SAS device page0 = 5000cca02acfc866
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x001f> enclosureHandle<0x0002> slot 21
mpr0: SAS Address from SAS device page0 = 5000cca02ad3c736
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0020> enclosureHandle<0x0002> slot 22
mpr0: SAS Address from SAS device page0 = 5000cca02ad195ba
mpr0: Found device <401<SspTarg>,End Device> <6.0Gbps> handle<0x0021> enclosureHandle<0x0002> slot 23
mpr0: SAS Address from SAS device page0 = 500a09800205a2fe
mpr0: Found device <4441<SspInit,SspTarg,SepDev>,End Device> <3.0Gbps> handle<0x0022> enclosureHandle<0x0002> slot 0
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a48d
mpr0: SAS Address from SAS device page0 = 5000cca02ad948f1
mpr0: SAS Address from SAS device page0 = 5000cca02ad964a1
mpr0: SAS Address from SAS device page0 = 5000cca02ad9b775
mpr0: SAS Address from SAS device page0 = 5000c5006800752d
mpr0: SAS Address from SAS device page0 = 5000cca02ad192cd
mpr0: SAS Address from SAS device page0 = 5000c5007156f1a5
mpr0: SAS Address from SAS device page0 = 5000cca02ad193d5
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ac79
mpr0: SAS Address from SAS device page0 = 5000cca02ad93e99
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a325
mpr0: SAS Address from SAS device page0 = 5000cca02ad193fd
mpr0: SAS Address from SAS device page0 = 5000cca02ad1aca9
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ecb5
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ab8d
mpr0: SAS Address from SAS device page0 = 5000cca02ad1ae31
mpr0: SAS Address from SAS device page0 = 5000c5007e101025
mpr0: SAS Address from SAS device page0 = 5000cca02ad1a3cd
mpr0: SAS Address from SAS device page0 = 5000cca02ad19b6d
mpr0: SAS Address from SAS device page0 = 5000cca02ad1adc1
mpr0: SAS Address from SAS device page0 = 5000cca02ad1eaa5
mpr0: SAS Address from SAS device page0 = 5000cca02acfc865
mpr0: SAS Address from SAS device page0 = 5000cca02ad3c735
mpr0: SAS Address from SAS device page0 = 5000cca02ad195b9
mpr0: SAS Address from SAS device page0 = 500a098001b440fe
da2 at mpr0 bus 0 scbus3 target 8 lun 0
da3 at mpr0 bus 0 scbus3 target 9 lun 0
da4 at mpr0 bus 0 scbus3 target 10 lun 0
da5 at mpr0 bus 0 scbus3 target 11 lun 0
da7 at mpr0 bus 0 scbus3 target 13 lun 0
da9 at mpr0 bus 0 scbus3 target 15 lun 0
da8 at mpr0 bus 0 scbus3 target 14 lun 0
da10 at mpr0 bus 0 scbus3 target 16 lun 0
da6 at mpr0 bus 0 scbus3 target 12 lun 0
da11 at mpr0 bus 0 scbus3 target 17 lun 0
da12 at mpr0 bus 0 scbus3 target 18 lun 0
da13 at mpr0 bus 0 scbus3 target 19 lun 0
da14 at mpr0 bus 0 scbus3 target 20 lun 0
da15 at mpr0 bus 0 scbus3 target 21 lun 0
da16 at mpr0 bus 0 scbus3 target 22 lun 0
da17 at mpr0 bus 0 scbus3 target 23 lun 0
da18 at mpr0 bus 0 scbus3 target 24 lun 0
da19 at mpr0 bus 0 scbus3 target 25 lun 0
da20 at mpr0 bus 0 scbus3 target 26 lun 0
da21 at mpr0 bus 0 scbus3 target 27 lun 0
da22 at mpr0 bus 0 scbus3 target 28 lun 0
da23 at mpr0 bus 0 scbus3 target 29 lun 0
da24 at mpr0 bus 0 scbus3 target 30 lun 0
da25 at mpr0 bus 0 scbus3 target 31 lun 0
ses0 at mpr0 bus 0 scbus3 target 36 lun 0
mpr0: _mapping_inc_missing_count: device is already removed from mapping table
mpr0: mprsas_prepare_remove: Sending reset for target ID 8
mpr0: da2: clearing target 8 handle 0x000a
mpr0: <NETAPP X412_HVIPC560A15 NA03> s/n LXYR95LN detached
mpr0: (da2:Unfreezing devq for target ID 8
mpr0:0:8:0): Periph destroyed
mpr0: mprsas_prepare_remove: Sending reset for target ID 9
mpr0: da3: <NETAPP X412_HVIPC560A15 NA03> s/n LXYVHGLN detached
(da3:mpr0:0:mpr0: 9:0): Periph destroyed
mpr0: Unfreezing devq for target ID 9
mpr0: mprsas_prepare_remove: Sending reset for target ID 10
mpr0: da4: clearing target 10 handle 0x000c
mpr0: <NETAPP X412_HVIPC560A15 NA03> s/n LXYVK9SN detached
(da4:mpr0: mpr0:0:Unfreezing devq for target ID 10
mpr0: mprsas_prepare_remove: Sending reset for target ID 11
mpr0: da5: clearing target 11 handle 0x000d
mpr0: <NETAPP X412_HVIPC560A15 NA03> s/n LXYVRUSN detached
(da5:mpr0: Unfreezing devq for target ID 11
mpr0:0:11:0): Periph destroyed
(probe0:mpr0:0:8:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 116 terminated ioc 804b loginfo 31110e05 scsi 0 state c xfer 0
(probe0:mpr0:0:8:0): CAM status: CCB request completed with an error
(probe0:mpr0:0:8:0): Retrying command
(probe1:mpr0:0:9:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 149 terminated ioc 804b loginfo 31110e05 scsi 0 state c xfer 0
(probe1:mpr0:0:9:0): CAM status: CCB request completed with an error
(probe1:mpr0:0:9:0): Retrying command
(probe2:mpr0:0:10:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 158 terminated ioc 804b loginfo 31110e05 scsi 0 state c xfer 0
(probe2:mpr0:0:10:0): CAM status: CCB request completed with an error
(probe2:mpr0:0:10:0): Retrying command
(probe3:mpr0:0:11:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 173 terminated ioc 804b loginfo 31110e05 scsi 0 state c xfer 0
(probe3:mpr0:0:11:0): CAM status: CCB request completed with an error
(probe3:mpr0:0:11:0): Retrying command
