Drives not detected by FreeNAS
The Takeover
my 2 SATA II Drives are visible in the BIOS, but when FreeNAS boots from the USB Stick, i get the follwing message and the drives are not shown. Only my cd drive and the usb stick where the IOS is running.
Hardware:
Mainboard: Gigabyte GA-MA78GM-S2H
RAM: 4GB
HDD: 2x WD 1TB
Thanks!
First, you need 8GB of RAM minimum just so that the WebGUI doesn't malfunction left and right.
Second, that error often is because your hard drive controllers aren't set to AHCI.
The Takeover
Thanks for your reply!
Ok, let me upgrade this for more performance, thanks!
But this should no problem for the volume issue?
Controller is set to AHCI (see Screenshot)
Do you got some more tips? :rolleyes:
WD EACS? Holy crap, those are ancient.
Can you try with different drives and/or validate that the current ones are working?
The Takeover
Haha yeeeeah...you're right :cool:
Yes, I will connect another drive and will test, if the drive is visible.
The ancient ones are working when I will connect them via external case -> USB.
Before I install Freenas, I've installed Windows Server on these HDD's. Maybe thats a problem.
Thanks!!!
Doesn't explain the timeouts, though.
It could be that the USB/SATA bridge is masking the problem, somehow, making them look like they're working.
The Takeover
So when I connect the hdd's external with my mac. Its say's that the drives can not be accessed.
So I formatted these drives and checked them..seems to be ok.
Volume „without titel“ check
Checking volume.
Checking main boot region.
Checking system files.
Volume name is without titel .
Checking upper case translation table.
Checking file system hierarchy.
Checking active bitmap.
Rechecking main boot region.
Rechecking alternate boot region.
The volume without titel appears to be OK.
There are formatted on Exfat right now, I will insert these drives now back to the freenas server and will continue this story.
Same problem..the hdd's are working fine. But not in the freenas server.
Any ideas?
Did you take my advice? We've had a dozen or more examples of people that couldn't create volumes with hard drive *just* because they didn't have 8GB of RAM.
The Takeover
Yes, I've ordered some more RAM. In the while I've tested NAS4Free who need not that much hardware performance..same issue:
Jan 29 19:12:17 nas4free syslogd: kernel boot file is /boot/kernel/kernel
Jan 29 19:12:17 nas4free kernel: Copyright (c) 1992-2014 The FreeBSD Project.
Jan 29 19:12:17 nas4free kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Jan 29 19:12:17 nas4free kernel: The Regents of the University of California. All rights reserved.
Jan 29 19:12:17 nas4free kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Jan 29 19:12:17 nas4free kernel: FreeBSD 9.3-RELEASE-p8 #0 r277306M: Sat Jan 17 21:53:14 CET 2015
Jan 29 19:12:17 nas4free kernel: root@dev.nas4free.org:/usr/obj/nas4free/usr/src/sys/NAS4FREE-amd64 amd64
Jan 29 19:12:17 nas4free kernel: gcc version 4.2.1 20070831 patched [FreeBSD]
Jan 29 19:12:17 nas4free kernel: CPU: AMD Athlon(tm) Dual Core Processor 4850e (2505.39-MHz K8-class CPU)
Jan 29 19:12:17 nas4free kernel: Origin = "AuthenticAMD"  Id = 0x60fb2  Family = 0xf  Model = 0x6b  Stepping = 2
Jan 29 19:12:17 nas4free kernel: Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Jan 29 19:12:17 nas4free kernel: Features2=0x2001<SSE3,CX16>
Jan 29 19:12:17 nas4free kernel: AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
Jan 29 19:12:17 nas4free kernel: AMD Features2=0x11f<LAHF,CMP,SVM,ExtAPIC,CR8,Prefetch>
Jan 29 19:12:17 nas4free kernel: real memory  = 6442450944 (6144 MB)
Jan 29 19:12:17 nas4free kernel: avail memory = 5877309440 (5605 MB)
Jan 29 19:12:17 nas4free kernel: Event timer "LAPIC" quality 400
Jan 29 19:12:17 nas4free kernel: ACPI APIC Table: <GBT    GBTUACPI>
Jan 29 19:12:17 nas4free kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Jan 29 19:12:17 nas4free kernel: FreeBSD/SMP: 1 package(s) x 2 core(s)
Jan 29 19:12:17 nas4free kernel: cpu0 (BSP): APIC ID:  0
Jan 29 19:12:17 nas4free kernel: cpu1 (AP): APIC ID:  1
Jan 29 19:12:17 nas4free kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Jan 29 19:12:17 nas4free kernel: ioapic0: Changing APIC ID to 2
Jan 29 19:12:17 nas4free kernel: ioapic0 <Version 2.1> irqs 0-23 on motherboard
Jan 29 19:12:17 nas4free kernel: kbd1 at kbdmux0
Jan 29 19:12:17 nas4free kernel: cryptosoft0: <software crypto> on motherboard
Jan 29 19:12:17 nas4free kernel: acpi0: <GBT GBTUACPI> on motherboard
Jan 29 19:12:17 nas4free kernel: acpi0: Power Button (fixed)
Jan 29 19:12:17 nas4free kernel: acpi0: reservation of 0, a0000 (3) failed
Jan 29 19:12:17 nas4free kernel: acpi0: reservation of 100000, bfce0000 (3) failed
Jan 29 19:12:17 nas4free kernel: cpu0: <ACPI CPU> on acpi0
Jan 29 19:12:17 nas4free kernel: cpu1: <ACPI CPU> on acpi0
Jan 29 19:12:17 nas4free kernel: attimer0: <AT timer> port 0x40-0x43 on acpi0
Jan 29 19:12:17 nas4free kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Jan 29 19:12:17 nas4free kernel: Event timer "i8254" frequency 1193182 Hz quality 100
Jan 29 19:12:17 nas4free kernel: hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Jan 29 19:12:17 nas4free kernel: Timecounter "HPET" frequency 14318180 Hz quality 950
Jan 29 19:12:17 nas4free kernel: Event timer "HPET" frequency 14318180 Hz quality 550
Jan 29 19:12:17 nas4free kernel: Event timer "HPET1" frequency 14318180 Hz quality 450
Jan 29 19:12:17 nas4free kernel: atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
Jan 29 19:12:17 nas4free kernel: Event timer "RTC" frequency 32768 Hz quality 0
Jan 29 19:12:17 nas4free kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Jan 29 19:12:17 nas4free kernel: acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
Jan 29 19:12:17 nas4free kernel: acpi_button0: <Power Button> on acpi0
Jan 29 19:12:17 nas4free kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Jan 29 19:12:17 nas4free kernel: pcib0: Length mismatch for 3 range: 2ed00000 vs 3ee10000
Jan 29 19:12:17 nas4free kernel: pci0: <ACPI PCI bus> on pcib0
Jan 29 19:12:17 nas4free kernel: pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
Jan 29 19:12:17 nas4free kernel: pci1: <ACPI PCI bus> on pcib1
Jan 29 19:12:17 nas4free kernel: vgapci0: <VGA-compatible display> port 0xee00-0xeeff mem 0xd0000000-0xdfffffff,0xfdfe0000-0xfdfeffff,0xfde00000-0xfdefffff irq 18 at device 5.0 on pci1
Jan 29 19:12:17 nas4free kernel: vgapci0: Boot video device
Jan 29 19:12:17 nas4free kernel: hdac0: <ATI RS780 HDA Controller> mem 0xfdffc000-0xfdffffff irq 19 at device 5.1 on pci1
Jan 29 19:12:17 nas4free kernel: pcib2: <ACPI PCI-PCI bridge> irq 18 at device 10.0 on pci0
Jan 29 19:12:17 nas4free kernel: pci2: <ACPI PCI bus> on pcib2
Jan 29 19:12:17 nas4free kernel: re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xde00-0xdeff mem 0xfdaff000-0xfdafffff,0xfdae0000-0xfdaeffff irq 18 at device 0.0 on pci2
Jan 29 19:12:17 nas4free kernel: re0: Using 1 MSI-X message
Jan 29 19:12:17 nas4free kernel: re0: Chip rev. 0x3c000000
Jan 29 19:12:17 nas4free kernel: re0: MAC rev. 0x00400000
Jan 29 19:12:17 nas4free kernel: miibus0: <MII bus> on re0
Jan 29 19:12:17 nas4free kernel: rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
Jan 29 19:12:17 nas4free kernel: rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
Jan 29 19:12:17 nas4free kernel: re0: Ethernet address: 00:1f:d0:8c:5a:89
Jan 29 19:12:17 nas4free kernel: ahci0: <AMD SB7x0/SB8x0/SB9x0 AHCI SATA controller> port 0xff00-0xff07,0xfe00-0xfe03,0xfd00-0xfd07,0xfc00-0xfc03,0xfb00-0xfb0f mem 0xfe02f000-0xfe02f3ff irq 22 at device 17.0 on pci0
Jan 29 19:12:17 nas4free kernel: ahci0: AHCI v1.10 with 6 3Gbps ports, Port Multiplier supported
Jan 29 19:12:17 nas4free kernel: ahcich0: <AHCI channel> at channel 0 on ahci0
Jan 29 19:12:17 nas4free kernel: ahcich1: <AHCI channel> at channel 1 on ahci0
Jan 29 19:12:17 nas4free kernel: ahcich2: <AHCI channel> at channel 2 on ahci0
Jan 29 19:12:17 nas4free kernel: ahcich3: <AHCI channel> at channel 3 on ahci0
Jan 29 19:12:17 nas4free kernel: ahcich4: <AHCI channel> at channel 4 on ahci0
Jan 29 19:12:17 nas4free kernel: ahcich5: <AHCI channel> at channel 5 on ahci0
Jan 29 19:12:17 nas4free kernel: ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02e000-0xfe02efff irq 16 at device 18.0 on pci0
Jan 29 19:12:17 nas4free kernel: usbus0 on ohci0
Jan 29 19:12:17 nas4free kernel: ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02d000-0xfe02dfff irq 16 at device 18.1 on pci0
Jan 29 19:12:17 nas4free kernel: usbus1 on ohci1
Jan 29 19:12:17 nas4free kernel: ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe02c000-0xfe02c0ff irq 17 at device 18.2 on pci0
Jan 29 19:12:17 nas4free kernel: ehci0: AMD SB600/700 quirk applied
Jan 29 19:12:17 nas4free kernel: usbus2: EHCI version 1.0
Jan 29 19:12:17 nas4free kernel: usbus2 on ehci0
Jan 29 19:12:17 nas4free kernel: ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02b000-0xfe02bfff irq 18 at device 19.0 on pci0
Jan 29 19:12:17 nas4free kernel: usbus3 on ohci2
Jan 29 19:12:17 nas4free kernel: ohci3: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02a000-0xfe02afff irq 18 at device 19.1 on pci0
Jan 29 19:12:17 nas4free kernel: usbus4 on ohci3
Jan 29 19:12:17 nas4free kernel: ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe029000-0xfe0290ff irq 19 at device 19.2 on pci0
Jan 29 19:12:17 nas4free kernel: ehci1: AMD SB600/700 quirk applied
Jan 29 19:12:17 nas4free kernel: usbus5: EHCI version 1.0
Jan 29 19:12:17 nas4free kernel: usbus5 on ehci1
Jan 29 19:12:17 nas4free kernel: atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfa00-0xfa0f at device 20.1 on pci0
Jan 29 19:12:17 nas4free kernel: ata0: <ATA channel> at channel 0 on atapci0
Jan 29 19:12:17 nas4free kernel: hdac1: <ATI SB600 HDA Controller> mem 0xfe024000-0xfe027fff irq 16 at device 20.2 on pci0
Jan 29 19:12:17 nas4free kernel: isab0: <PCI-ISA bridge> at device 20.3 on pci0
Jan 29 19:12:17 nas4free kernel: isa0: <ISA bus> on isab0
Jan 29 19:12:17 nas4free kernel: pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
Jan 29 19:12:17 nas4free kernel: pci3: <ACPI PCI bus> on pcib3
Jan 29 19:12:17 nas4free kernel: pci3: <serial bus, FireWire> at device 14.0 (no driver attached)
Jan 29 19:12:17 nas4free kernel: ohci4: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe028000-0xfe028fff irq 18 at device 20.5 on pci0
Jan 29 19:12:17 nas4free kernel: usbus6 on ohci4
Jan 29 19:12:17 nas4free kernel: amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb4
Jan 29 19:12:17 nas4free kernel: fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
Jan 29 19:12:17 nas4free kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Jan 29 19:12:17 nas4free kernel: ppc0: <Parallel port> port 0x378-0x37f irq 7 on acpi0
Jan 29 19:12:17 nas4free kernel: ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
Jan 29 19:12:17 nas4free kernel: ppbus0: <Parallel port bus> on ppc0
Jan 29 19:12:17 nas4free kernel: plip0: <PLIP network interface> on ppbus0
Jan 29 19:12:17 nas4free kernel: lpt0: <Printer> on ppbus0
Jan 29 19:12:17 nas4free kernel: lpt0: Interrupt-driven port
Jan 29 19:12:17 nas4free kernel: ppi0: <Parallel I/O> on ppbus0
Jan 29 19:12:17 nas4free kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Jan 29 19:12:17 nas4free kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Jan 29 19:12:17 nas4free kernel: kbd0 at atkbd0
Jan 29 19:12:17 nas4free kernel: atkbd0: [GIANT-LOCKED]
Jan 29 19:12:17 nas4free kernel: sc0: <System console> at flags 0x100 on isa0
Jan 29 19:12:17 nas4free kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Jan 29 19:12:17 nas4free kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Jan 29 19:12:17 nas4free kernel: powernow0: <PowerNow! K8> on cpu0
Jan 29 19:12:17 nas4free kernel: powernow1: <PowerNow! K8> on cpu1
Jan 29 19:12:17 nas4free kernel: ZFS filesystem version: 5
Jan 29 19:12:17 nas4free kernel: ZFS storage pool version: features support (5000)
Jan 29 19:12:17 nas4free kernel: Timecounters tick every 1.000 msec
Jan 29 19:12:17 nas4free kernel: ipfw2 (+ipv6) initialized, divert loadable, nat loadable, default to accept, logging disabled
Jan 29 19:12:17 nas4free kernel: iSCSI boot driver version 0.2.8
Jan 29 19:12:17 nas4free kernel: hdacc0: <ATI RS690/780 HDA CODEC> at cad 0 on hdac0
Jan 29 19:12:17 nas4free kernel: hdaa0: <ATI RS690/780 Audio Function Group> at nid 1 on hdacc0
Jan 29 19:12:17 nas4free kernel: pcm0: <ATI RS690/780 (HDMI)> at nid 3 on hdaa0
Jan 29 19:12:17 nas4free kernel: hdacc1: <Realtek ALC889A HDA CODEC> at cad 0 on hdac1
Jan 29 19:12:17 nas4free kernel: hdaa1: <Realtek ALC889A Audio Function Group> at nid 1 on hdacc1
Jan 29 19:12:17 nas4free kernel: pcm1: <Realtek ALC889A (Rear Analog 7.1/2.0)> at nid 20,22,21,23 and 24,26 on hdaa1
Jan 29 19:12:17 nas4free kernel: pcm2: <Realtek ALC889A (Front Analog)> at nid 27 and 25 on hdaa1
Jan 29 19:12:17 nas4free kernel: pcm3: <Realtek ALC889A (Rear Digital)> at nid 30 and 31 on hdaa1
Jan 29 19:12:17 nas4free kernel: xmd version 0.4.2 by NAS4Free Project (experimental)
Jan 29 19:12:17 nas4free kernel: xmd: default blocklen 32KB, compression LZ4/LZ4HC, level 6
Jan 29 19:12:17 nas4free kernel: xmd0: Loaded preload cloop image </mfsroot.uzip> 13577728 bytes at 0xffffffff81eacee0 (128MB disk w/LZ4)
Jan 29 19:12:17 nas4free kernel: usbus0: 12Mbps Full Speed USB v1.0
Jan 29 19:12:17 nas4free kernel: usbus1: 12Mbps Full Speed USB v1.0
Jan 29 19:12:17 nas4free kernel: usbus2: 480Mbps High Speed USB v2.0
Jan 29 19:12:17 nas4free kernel: usbus3: 12Mbps Full Speed USB v1.0
Jan 29 19:12:17 nas4free kernel: usbus4: 12Mbps Full Speed USB v1.0
Jan 29 19:12:17 nas4free kernel: usbus5: 480Mbps High Speed USB v2.0
Jan 29 19:12:17 nas4free kernel: usbus6: 12Mbps Full Speed USB v1.0
Jan 29 19:12:17 nas4free kernel: ugen0.1: <ATI> at usbus0
Jan 29 19:12:17 nas4free kernel: uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Jan 29 19:12:17 nas4free kernel: ugen1.1: <ATI> at usbus1
Jan 29 19:12:17 nas4free kernel: uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Jan 29 19:12:17 nas4free kernel: ugen2.1: <ATI> at usbus2
Jan 29 19:12:17 nas4free kernel: uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
Jan 29 19:12:17 nas4free kernel: ugen3.1: <ATI> at usbus3
Jan 29 19:12:17 nas4free kernel: uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
Jan 29 19:12:17 nas4free kernel: ugen4.1: <ATI> at usbus4
Jan 29 19:12:17 nas4free kernel: uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
Jan 29 19:12:17 nas4free kernel: ugen5.1: <ATI> at usbus5
Jan 29 19:12:17 nas4free kernel: uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
Jan 29 19:12:17 nas4free kernel: ugen6.1: <ATI> at usbus6
Jan 29 19:12:17 nas4free kernel: uhub6: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:15:0): CAM status: Command timeout
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:15:0): Error 5, Retries exhausted
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:15:0): CAM status: Command timeout
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:15:0): Error 5, Retries exhausted
Jan 29 19:12:17 nas4free kernel: uhub6: 2 ports with 2 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub0: 3 ports with 3 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub1: 3 ports with 3 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub3: 3 ports with 3 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub4: 3 ports with 3 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub2: 6 ports with 6 removable, self powered
Jan 29 19:12:17 nas4free kernel: uhub5: 6 ports with 6 removable, self powered
Jan 29 19:12:17 nas4free kernel: ugen2.2: <USB 2.0> at usbus2
Jan 29 19:12:17 nas4free kernel: umass0: <USB 2.0 FlashDisk, class 0/0, rev 2.00/10.00, addr 2> on usbus2
Jan 29 19:12:17 nas4free kernel: umass0:  SCSI over Bulk-Only; quirks = 0x0100
Jan 29 19:12:17 nas4free kernel: umass0:7:0:-1: Attached to scbus7
Jan 29 19:12:17 nas4free kernel: ahcich0: Timeout on slot 0 port 0
Jan 29 19:12:17 nas4free kernel: ahcich0: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:0:0): CAM status: Command timeout
Jan 29 19:12:17 nas4free kernel: (aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked
Jan 29 19:12:17 nas4free kernel: ahcich2: Timeout on slot 0 port 0
Jan 29 19:12:17 nas4free kernel: ahcich2: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:0:0): CAM status: Command timeout
Jan 29 19:12:17 nas4free kernel: (aprobe1:ahcich2:0:0:0): Error 5, Retry was blocked
Jan 29 19:12:17 nas4free kernel: run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config
Jan 29 19:12:17 nas4free kernel: SMP: AP CPU #1 Launched!
Jan 29 19:12:17 nas4free kernel: cd0 at ata0 bus 0 scbus6 target 0 lun 0
Jan 29 19:12:17 nas4free kernel: cd0: <HL-DT-ST DVD-RAM GH22NP20 1.01> Removable CD-ROM SCSI-0 device
Jan 29 19:12:17 nas4free kernel: cd0: 66.700MB/s transfers (UDMA4, ATAPI 12bytes, PIO 65534bytes)
Jan 29 19:12:17 nas4free kernel: cd0: Attempt to query device size failed: NOT READY, Medium not present
Jan 29 19:12:17 nas4free kernel: da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
Jan 29 19:12:17 nas4free kernel: da0: <USB 2.0 FlashDisk 1.00> Removable Direct Access SCSI-0 device
Jan 29 19:12:17 nas4free kernel: da0: Serial Number 03131025573565
Jan 29 19:12:17 nas4free kernel: da0: 40.000MB/s transfers
Jan 29 19:12:17 nas4free kernel: da0: 1948MB (3989504 512 byte sectors: 255H 63S/T 248C)
Jan 29 19:12:17 nas4free kernel: da0: quirks=0x2<NO_6_BYTE>
Jan 29 19:12:17 nas4free kernel: Trying to mount root from ufs:/dev/xmd0 []...
Jan 29 19:12:17 nas4free kernel: 3         15 s 56.0 %        28.0 MiB / 402.0 MiB = 0.070    29 MiB/s       0:14         10 s 61.3 %        30.7 MiB / 411.6 MiB = 0.074    27 MiB/s       0:15          9 s 66.5 %        33.3 MiB / 421.0 MiB = 0.079    26 MiB/s       0:16          8 s 71.5 %        35.8 MiB / 432.0 MiB = 0.083    25 MiB/s       0:17          6 s 75.7 %        37.9 MiB / 442.0 MiB = 0.086    25 MiB/s       0:18          5 s 78.2 %        39.1 MiB / 467.0 MiB = 0.084    25 MiB/s       0:19          5 s 81.6 %        40.9 MiB / 486.0 MiB = 0.084    24 MiB/s       0:20          4 s 85.9 %        43.0 MiB / 496.6 MiB = 0.087    24 MiB/s       0:21          3 s 89.9 %        45.0 MiB / 509.0 MiB = 0.088    23 MiB/s       0:22          2 s 93.9 %        47.0 MiB / 522.0 MiB = 0.090    23 MiB/s       0:23          1 s 96.2 %        48.1 MiB / 534.0 MiB = 0.090    22 MiB/s       0:24          1 s 98.7 %        49.4 MiB / 547.0 MiB = 0.090    22 MiB/s       0:25          1 s 99.7 %        49.9 MiB / 627.9 MiB = 0.079    24 MiB/
Jan 29 19:12:17 nas4free kernel: 0:26          1 s 99.9 %        50.0 MiB / 737.7 MiB = 0.068    27 MiB/s       0:27          1 s  100 %        50.0 MiB / 768.0 MiB = 0.065    28 MiB/s       0:27
Jan 29 19:12:17 nas4free mDNSResponderPosix: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C2FD60 nas4free.local. (Addr) that's already in the list
Jan 29 19:12:17 nas4free mDNSResponderPosix: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C30180 250.1.168.192.in-addr.arpa. (PTR) that's already in the list
Jan 29 19:12:17 nas4free mDNSResponderPosix: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C31D60 nas4free.local. (AAAA) that's already in the list
Jan 29 19:12:17 nas4free mDNSResponderPosix: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C32180 9.8.A.5.C.8.E.F.F.F.0.D.F.1.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. (PTR) that's already in the list
Jan 29 19:12:18 nas4free lighttpd[1948]: (log.c.164) server started
Jan 29 19:12:18 nas4free mDNSResponderPosix: mDNSPlatformSendUDP got error 50 (Network is down) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 192.168.1.250/re0/1
Jan 29 19:12:18 nas4free login: login on ttyv0 as root
Jan 29 19:12:19 nas4free mDNSResponderPosix: mDNSPlatformSendUDP got error 50 (Network is down) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 192.168.1.250/re0/1
Jan 29 19:12:20 nas4free mDNSResponderPosix: mDNSPlatformSendUDP got error 50 (Network is down) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 192.168.1.250/re0/1
Jan 29 19:12:22 nas4free mDNSResponderPosix: mDNSPlatformSendUDP got error 50 (Network is down) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 192.168.1.250/re0/1
Jan 29 19:12:26 nas4free mDNSResponderPosix: mDNSPlatformSendUDP got error 50 (Network is down) sending packet to FF02:0000:0000:0000:0000:0000:0000:00FB on interface 192.168.1.250/re0/1
Jan 29 19:16:47 nas4free root: rcconf service executed
Jan 29 19:16:47 nas4free kernel: ifa_del_loopback_route: deletion failed
Jan 29 19:16:48 nas4free kernel: re0: link state changed to DOWN
Jan 29 19:16:51 nas4free kernel: re0: link state changed to UP
Jan 29 19:16:58 nas4free dhclient: New IP Address (re0): 192.168.2.27
Jan 29 19:16:58 nas4free dhclient: New Subnet Mask (re0): 255.255.255.0
Jan 29 19:16:58 nas4free dhclient: New Broadcast Address (re0): 192.168.2.255
Jan 29 19:16:58 nas4free dhclient: New Routers (re0): 192.168.2.1
Jan 29 19:17:01 nas4free root: netif service restarted
Jan 29 19:17:01 nas4free root: routing service restarted
Jan 29 19:17:01 nas4free dhclient[3149]: connection closed
Jan 29 19:17:01 nas4free dhclient[3149]: exiting.
Jan 29 19:17:01 nas4free kernel: re0: link state changed to DOWN
Jan 29 19:17:04 nas4free kernel: re0: link state changed to UP
Jan 29 19:17:10 nas4free dhclient: New IP Address (re0): 192.168.2.27
Jan 29 19:17:10 nas4free dhclient: New Subnet Mask (re0): 255.255.255.0
Jan 29 19:17:10 nas4free dhclient: New Broadcast Address (re0): 192.168.2.255
Jan 29 19:17:10 nas4free dhclient: New Routers (re0): 192.168.2.1
Jan 29 19:17:10 nas4free root: resolv service restarted
Jan 29 19:17:10 nas4free lighttpd[1948]: (server.c.1558) server stopped by UID = 0 PID = 3469
Jan 29 19:17:10 nas4free lighttpd[3554]: (log.c.164) server started
Jan 29 19:17:10 nas4free root: lighttpd service restarted
Jan 29 19:17:39 nas4free root: Authentication error for illegal user : root from 192.168.2.1
Jan 29 19:18:44 nas4free kernel: (aprobe0:ahcich0:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
Jan 29 19:18:44 nas4free kernel: (aprobe0:ahcich0:0:15:0): CAM status: Command timeout
Jan 29 19:18:44 nas4free kernel: (aprobe0:ahcich0:0:15:0): Error 5, Retries exhausted
Jan 29 19:19:14 nas4free kernel: ahcich0: Timeout on slot 0 port 0
Jan 29 19:19:14 nas4free kernel: ahcich0: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:19:14 nas4free kernel: (aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:19:14 nas4free kernel: (aprobe0:ahcich0:0:0:0): CAM status: Command timeout
Jan 29 19:19:14 nas4free kernel: (aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked
Jan 29 19:19:44 nas4free kernel: ahcich0: Timeout on slot 0 port 0
Jan 29 19:19:44 nas4free kernel: ahcich0: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich0:0:0:0): CAM status: Command timeout
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich2:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich2:0:15:0): CAM status: Command timeout
Jan 29 19:19:44 nas4free kernel: (aprobe0:ahcich2:0:15:0): Error 5, Retries exhausted
Jan 29 19:20:08 nas4free root: htpasswd service executed
Jan 29 19:20:14 nas4free kernel: ahcich2: Timeout on slot 0 port 0
Jan 29 19:20:14 nas4free kernel: ahcich2: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:20:14 nas4free kernel: (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:20:14 nas4free kernel: (aprobe0:ahcich2:0:0:0): CAM status: Command timeout
Jan 29 19:20:14 nas4free kernel: (aprobe0:ahcich2:0:0:0): Error 5, Retry was blocked
Jan 29 19:20:44 nas4free kernel: ahcich2: Timeout on slot 0 port 0
Jan 29 19:20:44 nas4free kernel: ahcich2: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
Jan 29 19:20:44 nas4free kernel: (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 29 19:20:44 nas4free kernel: (aprobe0:ahcich2:0:0:0): CAM status: Command timeout
Jan 29 19:20:44 nas4free kernel: (aprobe0:ahcich2:0:0:0): Error 5, Retry was blocked
Same issue.
Do you got some more tips, please?
I don't. Frankly as soon as someone says they are using an AMD machine I rapidly lose interest and ideas because AMDs can cause problems that I willingly choose not to deal with or get involved in. It's not a secret that AMD and FreeBSD have never had a great loving relationship.
All that being said, I think that motherboard is the same one that one of our regulars uses, so I'd expect it to work. But why yours isn't working or how to make it work is beyond me. AMDs have always been a nightmare for me and so I refuse to even fix AMD based desktops because I seem to always break them more than when they show up at my house. Give me an Intel system and I can fix those all day long.
