Driver installation for raid board
zz25
Greetings to the whole forum.
I bought a used computer for a few euros to create a nas, and when I opened it I noticed that it has an ASR 6405E 128MB raid card to which 2 x 4TB HDs are connected.
I have installed freenas on an old HD SSD, but when I enter the configurations the 2 HDs are not visible.
I don't have great skills, so I need someone to teach me step by step how to install the card driver to be able to manage the 2 HDs.
Thanks in advance.
Greetings
jgreco
Resident Grinch
Please try connecting the hard drives directly to the mainboard. The ASR card is not usable.
zz25
Thanks to both of you for the replies.
I removed the card and now I see both two discs. Now I have another problem. I have followed many tutorials of truenas, but when I try to add the created folder to network resources, by entering IP address and folder name, I cannot access it, as if the user is not recognized. I have activated SMB on the pc but I cannot see the folder. Could you please help me? Thank you Greetings
Could you share some screenshots of how you have configured your share?
zz25
Hi sretalla and thanks for yuor intersting
Below you can find the configuration of my truenas.
I've seen many tutorials and i followed them for configuration.
I trust in your help in solving my problem.
Thanks
  • 1.pdf
  • 2.pdf
  • 3.pdf
  • 6.pdf
  • 5.pdf
  • 4.pdf
  • 7.pdf
  • 8.pdf
OK, so from 6.pdf, we can see that you haven't made your user the owner.
You need to put your user there as the root user can't be the owner of a share.
You should also check the box to apply user after that.
zz25
Hi sretalla and thank again for your valuable help.
I've done what you suggested but i've again the same problem.
I don't know how to do
Regards
  • 6.1.pdf
zz25
Please sretall, see attached file
  • 9.pdf
