Fattrain
- Jul 22, 2013
So this is my first time super n00b post. Long story short I have a long history in IT but am really just starting to cut my teeth with FreeBSD / FreeNAS storage system.
I have a 5 x 3tb drive setup and my daily report came across my phone and said "Degraded"! Aghhh!!! So I logged in and took a look using ZPool status and sure enough one of my drives was "offline".
I rebooted, checked bios to make sure all 5 drives were showing and they were. I opened a CLI in FreeNAS and did "camcontrol devlist" and all 5 drives show there as well. I then did gpart show and found that "ada1" wasn't listed.
Following some threads I found online (hopefully not to a fault) I did a zpool online TrainData /gptid/efe98h893hj3 (just an example of the command)
Now my greenlight shows in the GUI like everything is OK but I don't trust it because when I do a ZPool status -v it still shows funky stuff (see 2 posts down)
Any help from you FreeNAS guru's would be MUCH appreciated. Thanks in advance!
EDIT: Posted originally in "quote" form (Doh!) and fixed it 2 posts down
