Drive unavailable in WebUI
espenu
I'm adding 3 500Gb drives to make an additional raidz1 array. However, I can only see 2 of them.
My motherboards on-board controller has 6 SATA connectors. 1 is used for FreeNAS, and I have an existing array of 4 drives.
Since I have 3 more drives I added a SATA controller and connected 2 of the drives to it.
However, when I try to make another volume in the WebUI I can only see two of the drives. The last one from the on-board, and the first from the extra controller.
If I use ssh I can see all 3 of them using gpart show, and I could also make a GPT partition table on all of them.
The drives (drive names as shown by gpart):
ada0 FreeNAS
ada1 Member of array1
ada2 Member of array1
ada3 Member of array1
ada4 Member of array1
ada5 "new" 500GB drive
da0 "new" 500GB drive
da1 "new" 500GB drive (missing in GUI)
So I have two options/questions.
1. Is there a way to make the WebUI see the last drive?
2. If not, is there a way to manually create an array by using ssh and make is show in the WebUI under Volumes?
By the way, I'm using FreeNAS 8.0
