Drive stop idling/sleeping, strange SMART ERROR
huberte
since 8.2.0p1, I think my drives are always on. So I'll ask my questions, here we go. thanks for your answers !
1. Could my drives stop idling/sleeping because of this "bug"/error ?
Sep 27 14:23:06 freenas init: getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs
Sep 27 14:23:38 freenas init: getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs
Sep 27 14:25:15 freenas last message repeated 3 times
Sep 27 14:35:31 freenas last message repeated 19 times
Sep 27 14:45:45 freenas last message repeated 19 times
Sep 27 14:55:28 freenas last message repeated 18 times
Sep 27 15:05:42 freenas last message repeated 19 times
Sep 27 15:15:58 freenas last message repeated 19 times
Sep 27 15:25:41 freenas last message repeated 18 times
Sep 27 15:35:56 freenas last message repeated 19 times
Sep 27 15:46:10 freenas last message repeated 19 times
Sep 27 15:49:25 freenas last message repeated 6 times
Sep 27 15:49:42 freenas ntpd[1592]: time reset +0.164133 s
Sep 27 15:49:57 freenas init: getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs
Sep 27 15:50:30 freenas init: getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs
Sep 27 15:52:39 freenas last message repeated 4 times
Sep 27 16:02:54 freenas last message repeated 19 times
Sep 27 16:12:37 freenas last message repeated 18 times
Sep 27 16:22:51 freenas last message repeated 19 times
Sep 27 16:33:07 freenas last message repeated 19 times
Sep 27 16:42:50 freenas last message repeated 18 times
Sep 27 16:53:05 freenas last message repeated 19 times
Sep 27 17:03:20 freenas last message repeated 19 times
Sep 27 17:13:03 freenas last message repeated 18 times
Sep 27 17:23:17 freenas last message repeated 19 times
Sep 27 17:33:33 freenas last message repeated 19 times
Sep 27 17:43:16 freenas last message repeated 18 times
Sep 27 17:53:31 freenas last message repeated 19 times
Sep 27 18:03:46 freenas last message repeated 19 times
Sep 27 18:13:29 freenas last message repeated 18 times
Sep 27 18:23:43 freenas last message repeated 19 times
Sep 27 18:33:58 freenas last message repeated 19 times
Sep 27 18:43:41 freenas last message repeated 18 times
Sep 27 18:53:56 freenas last message repeated 19 times
Sep 27 19:04:12 freenas last message repeated 19 times
Sep 27 19:13:54 freenas last message repeated 18 times
Sep 27 19:24:09 freenas last message repeated 19 times
Sep 27 19:34:25 freenas last message repeated 19 times
Sep 27 19:44:07 freenas last message repeated 18 times
2. I have installed modules, firefly and sabnzb. should I stop the service to make my drives sleep ? Should I install jail, firefly, sabnzb on another hard drive ?
3. what is this strange smartctl error ?
Sep 27 14:22:45 freenas smartd[1850]: Device: /dev/ada1, 586 Currently unreadable (pending) sectors
why does it stop the entire SMART short auto-test ?
3bis. I did put the sleep mode according to the AAM from ataidle, is it correct, for example
Vendor Recommended AAM: 127
4. Finally, sometimes, my left column does not show up in webgui, why ?
Stephens
I hope you have a backup of any data you care about on that drive. If not, start backing up the data right away. The drive probably needs to be replaced. After you've backed up your data, you can run a smartctl long test from the console/shell to see what's going on. If that's OK, which I doubt, then you can do a scrub. But start getting your head around a drive replacement.
I like the answer provided here about what the error is.
paleoN
The jail by itself will keep the disk from idling. Search the forums and you will find this has been discussed.
As Stephens said the drive needs to be replaced. FYI, a SMART test will stop on the first error.
