Drive problem apparently.
rdl
Help. What is this telling me? Unrecoverable drive not ready error?
freenas.local kernel log messages:
(ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 90 10 a0 41 40 b4 00 00 00 00 00
(ada2:ahcich2:0:0:0): CAM status: ATA Status Error
(ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
(ada2:ahcich2:0:0:0): RES: 41 40 10 a0 41 40 b4 00 00 00 00
(ada2:ahcich2:0:0:0): Retrying command
-- End of security output --
Smartctl -a says no errors
Thanks for any help.
I bet it says much more than that...
Please post the output and we'll help you to see the lines that matter.
It could be cabling, so ask yourself if you may have touched/knocked the cable doing anything recently.
rdl
I only ran the short test yesterday. I didn't get a security report today, I guess there were no errors. I did move the computer a couple of weeks ago. It's a Gen 7 Microserver, doesn't have much in the way of cables but I'll check anyway. Drive is a WD Blue 2 TB. If this isn't the info you wanted let me know and I'll try again. I'm not at all familiar with this stuff and I really don't know what I'm doing. Should I run the longer test?
SMART Attributes Data Structure revision number​
Vendor Specific SMART Attributes with Thresholds​
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE​
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0​
3 Spin_Up_Time 0x0027 167 165 021 Pre-fail Always - 6641​
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 546​
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0​
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0​
9 Power_On_Hours 0x0032 060 060 000 Old_age Always - 29320​
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0​
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0​
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15​
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 3​
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1991​
194 Temperature_Celsius 0x0022 120 114 000 Old_age Always - 30​
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0​
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0​
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0​
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0​
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0​
SMART Error Log Version​
No Errors Logged​
SMART Self-test log structure revision number 1​
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error​
# 1 Short offline Completed without error 00% 29319 -​
# 2 Extended offline Completed without error 00% 8 -​
# 3 Conveyance offline Completed without error 00% 0 -​
# 4 Short offline Completed without error 00% 0 -​
SMART Selective self-test log data structure revision number 1​
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS​
1 0 0 Not_testing​
2 0 0 Not_testing​
3 0 0 Not_testing​
4 0 0 Not_testing​
5 0 0 Not_testing​
Selective self-test flags (0x0)​
So the last extended/long test you ran was when the drive was 8 hours old and you ran the last short test at 29K hours.
You could run a long test (and wait for it to finish) before looking again at the results.
rdl
So I was stupid and ran the test on the wrong drive. Here is the correct drive and I can see what looks like problems. I don't know exactly what they mean, but they're different from the other drive. These are the first two drives I put in and luckily most of what's on them was long ago copied to the WD Red drives I added later.
16​
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 571​
3 Spin_Up_Time 0x0027 174 172 021 Pre-fail Always - 4258​
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1141​
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 1​
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0​
9 Power_On_Hours 0x0032 039 039 000 Old_age Always - 44937​
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 33​
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 7​
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 14795​
194 Temperature_Celsius 0x0022 116 111 000 Old_age Always - 31​
196 Reallocated_Event_Count 0x0032 199 199 000 Old_age Always - 1​
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 11​
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 5​
200 Multi_Zone_Error_Rate 0x0008 199 199 000 Old_age Offline - 781​
1​
No Errors Logged​
Yep, that's a dead (or very nearly dead) drive.
