thecoffeeguy
- Apr 5, 2014
Hey Folks.
Well, had my first drive fail on me last night, which was a new experience for me.
In a quick summary, I use my FreeNAS primarily for development/testing stuff and storage/backups VM's.
I have been toying lately of running VM's off of FreeNAS from my vCenter server via iSCSI. Seemed to work ok, me thinks, but i could be wrong.
Anyway, I was doing some work on one of my VM's and noticed it was abnormally slow. Did some digging around and saw the IO was bad (this VM is being run off FreeNAS).
I logged into FreeNAS and was greeted with a lovely warning about a degraded pool.
Some googling and digging around, looks like a drive has died or is dying.
I am not a FreeNAS expert, but i love the product (grew up on FreeBSD).
My only asks/questions I have to the folks here is:
1.) anyway I can figure out what caused the drive to die? Could there be any relation to the VM causing issues on the storage? The VM itself did have some database stuff work it was doing.
2.) I ordered a couple of disks as replacements and plan to plug them in when I get them. My question is, should I just add them to the pool? This is where my lack of experience comes in.
3.) lastly, does it matter if the drives are the same size? spec? model? These were older drives (probably 7 years ago or so), 2 TB. Here is smartctl output:
Thats about it. Not terribly worried as this is not production, but want to take steps to resolve the issue and make it better.
Much obliged for the help.
TCG
== START OF INFORMATION SECTION === Model Family: Western Digital Green Device Model: WDC WD20EARX-00PASB0 Serial Number: WD-WMAZA7232126 LU WWN Device Id: 5 0014ee 206c3ed23 Firmware Version: 51.0AB51 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sun Feb 16 13:31:16 2020 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled
TCG
